Low Tire
I've been told by the service department that this system is different than the SC system. That one uses a small battery in each wheel and a sensor in the tire stem to monitor the air pressure.
The system in the LS only monitors the tire rotation and when it detects a different amount of rotation from one tire over a certain period of time, it turns on the warning. This system does not know how much pressure is in each tire and when the warning light goes on, it doesn't even tell you which tire it had detected.
I've heard from Corvette owners who have the system like the SC, that when the battery goes out or the sensor is damaged it costs a few hundred dollara to replace, so maybe that is why Lexus is trying this system.
Although I've only had the system a few months, my opinion is negative. Since it doesn't tell you which tire it thinks is low, you really can't tell if it's a false reading unless the tire is very low. So you just reset the indicator and go. In the manual, it states some of the conditions which could set it off are drving in snow, very cold tempatures, very hot tempatures, and other things. I would rather put up with the expense of the other system for the accurate information.
I think for those of us who live in cold snowy areas, the Low Tire Monitor system is going to be a problem. I am very surprised that Lexus would put a system on the LS that is prone to false warnings for many of us that drive in conditions that are just normal winter driving.
This is my first Lexus and I don't know how they are at addressing issues like these, but just from our experiences, it would seem like they need to make some modifications. As I said, I would rather have it disconnected than put up with all false reading.
If anyone has any ideas on how to organize and bring this to Lexus' attention, count me in!
as I understand it, this system does not have anything to do with the tire pressure, but somehow measures the tire revolutions and when it detects a variation at one or more of the wheels, it turns on the warning. If you notice, it never tells you the actual pressure of any tire and it doesn't even tell you which tire it thinks is low. This is what service advisors at two different dealers told me. They also said this is a new system and as of December they had no experience with it. If our experience is any indication they will become very familiar with it very soon.
The first time mine went off after driving in a few inches of snow, I checked my tires with a dial gauge and they were all within the range of 35 to 35 1/2 pounds.
My question is will they only make changes to future models or correct our systems also?
After a few months of experimenting, I discovered that it was always going on almost exactly 10 or 11 miles after I started out somewhere. If I drove 7 miles then stopped and then another 7 it would not go on. So the main thing was that it was totally consistent that when I drove 10-11 miles without turning the car off on the light would go. I brought it in to the dealer again for my 15,000 mile checkup and still with this info they couldn't figure it out. But the night I left it for service I found this forum w the note from JenniferG and MAlaimo and it all fit together. This thing has nothing to do with temperature or anything else. It has to do with how they adjust the tires and if something is slightly "off" then the light can come on. After the 15,000 mile checkup and whatever they did w tire rotation, the problem is gone. I am getting snow tires soon and half expect the problem will come back. Bottom line is this system is not quite ready for prime time and there are probably some tire adjustment pointers the service people need to be aware of to quickly solve this problem for people when it occurs.
I think you have to complain about the problem before they will make the change.
