Steering Wheel Shake over Bumps
Old Jan 24, 2026 | 09:32 PM
SSCARO's Avatar
SSCARO
Default Steering Wheel Shake over Bumps
2004 LS430 UL with 126k miles. I am experiencing a rubbery sort of steering wheel shake over significant bumps. Ball joints and outer tie rod ends have been replaced.
What would cause this? Thanks.
Old Jan 25, 2026 | 03:58 PM
jimisbell's Avatar
jimisbell
Front Struts !!
Old Jan 25, 2026 | 07:07 PM
lkb's Avatar
lkb
10th Gear
Ya my struts are due for replacement and I'm getting the same issue.
Old Jan 26, 2026 | 03:06 AM
BigBoomer's Avatar
BigBoomer
I had the same and new front struts fixed the problem 100%.
Essentially your front shock absorbers are no longer damping adequately which leads to one side vibrating up and down more than it should and that leads to a vibration or shudder in the steering wheel after driving over a bump, sometimes even over a small ripple.
Mine started off only reacting to big bumps, but got worse as time went by. Then I got an "advisory" of oil weeping from the front right strut. Once the struts were replaced the car felt new again.
Mine has the air-suspension so I used aftermarket air-struts which so far are 6 months/5000 miles in and still feel great.
Old Jan 26, 2026 | 05:46 AM
SSCARO's Avatar
SSCARO
Which aftermarket struts did you use? Thanks.
Old Jan 26, 2026 | 08:38 AM
jimisbell's Avatar
jimisbell
Lexus OE. Only way to go, In the long run, you save money.
Old Jan 26, 2026 | 08:40 AM
BigBoomer's Avatar
BigBoomer
I used these. OE are stupidly expensive.
https://www.ebay.co.uk/itm/226720587264
Old Jan 26, 2026 | 09:39 AM
SSCARO's Avatar
SSCARO
I used similar air struts on the rear of my car. They’ve been on over a year and are still much better than what I took off. I have a pair of salvage front struts but am reluctant to use them. They would be 20 years old and have been sitting in my garage for a couple of years. 20 year old air bladders are probably not in good shape.
thanks!
Old Jan 26, 2026 | 10:38 AM
zoomee99's Avatar
zoomee99
Worn out Steering Rack Bushings. I had same issue with my 04, big steering shake after hitting bumps at highway speed. I replaced front struts and LCAs but no change. Then following advice found on Club Lexus I replaced Steering Rack bushings. Perfect 100% fix, easy DIY does not require alignment afterwards.
Part numbers, 2 per side about $60 ea. OEM. There are cheaper ones out there but I would stick with OEM
45516-50030 Drivers side
45516-50040 Pass side
Lexus does not sell these individually for 2004-06 (they want you to buy a whole new steering rack instead..WTF?) so you have to look under 2001-03 to find them...but they do fit all years.
Old Jan 26, 2026 | 01:26 PM
erapmicks's Avatar
erapmicks
Lexus does not sell these for 2004-06 so you have to look under 2001-03 to find them...but they do fit all years.
Does it require to remove the rack off the vehicle?
Old Jan 26, 2026 | 01:54 PM
zoomee99's Avatar
zoomee99
You just remove two mounting studs. Unfasten the nuts then the studs unscrew from the frame. You don't need to remove tie rods or anything else. Advise having two sets of hands for reassembly, the rack is heavy and awkward. Look around on CL there is a "how to"...the tabs on the new bushings need to line up a certain way, check the procedure for instructions. Here are threads that help understand.
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/897336-daizen-steering-rack-bushing-installation.html
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/553981-steering-looseness-is-that-a-word.html
riyu
May 3, 2025 04:42 AM
biacs
May 11, 2018 11:36 AM
GregoryNP
Jun 5, 2014 09:10 AM
bonafyd
Feb 24, 2008 04:16 PM
