2003 LS430 rear trunk cargo net.
Old Dec 2, 2025 | 12:16 PM
Quinten's Avatar
Quinten
Default 2003 LS430 rear trunk cargo net.
Trying to find out what hardware is needed to attach the rear cargo net. Car came without a net and it seems the upper plastic anchors were never installed. Drivers side has a broken retainer and passenger side is just the plastic rivet. I believe the lower anchors are metal rings and the upper may differ between PFL and later models? Do the upper anchors screw in to a speed nut or are they a press fit?
I didn't think it would be much of an issue to get a cargo net but so far I'm not really sure what to look for with the upper anchors.
Old Dec 2, 2025 | 12:57 PM
alextv's Avatar
alextv
We never use ours as it never worked well.
Old Dec 2, 2025 | 01:28 PM
Quinten's Avatar
Quinten
My wife uses the cargo net in her ES330 all the time and now that I got her a LS430 she wants the cargo net. The one in the ES works well with grocery bags and that's her main use for the cargo net. The one in my Pontiac G8 is pretty shallow and doesn't work too well either but the taller ES one works pretty well and would think the LS one would too. Just trying to find out the upper mount design and if it differs for the PFL models.
Old Dec 2, 2025 | 03:01 PM
alextv's Avatar
alextv
Don't really remember but I think there were different configurations. For the upper anchors look up the part and see if there is a picture to see if screws in but I am thinking it probably just pops in. Ok just remembered I had to pop out some to run a wire to trunk at top so it does not screw in.
Old Dec 2, 2025 | 03:22 PM
Quinten's Avatar
Quinten
All the diagrams I've found are pretty crude drawings so it's hard to tell. What year is your LS?
Old Dec 2, 2025 | 03:25 PM
CA2WALS430's Avatar
CA2WALS430
Mine was set up when I got the car 6 years and I took it down so it is tough to recall but I think it was double-wrapped on the clips or something like that.
Old Dec 3, 2025 | 01:25 AM
Dusty61's Avatar
Dusty61
Default Trunk cargo net hook
This is the hook from my LS430 2004. Gets chewed up by the sharp edges of the mounting hole which has slots to take the two lugs then turn into position.
Old Dec 3, 2025 | 01:45 AM
Quinten's Avatar
Quinten
Thanks for pics... not sure where I'm going to find them! I may go to the pick a part yard here and see what they may have as they show both a 2002 and a 2004 LS430.
Old Dec 3, 2025 | 01:54 AM
BigBoomer's Avatar
BigBoomer
My 2004 has the factory cargo net.
So far as I can tell it was intended to be mounted in the middle of the trunk and is of limited use.
Mine mostly lives with the spare wheel but occasionally comes out if I have lots of small loose items to store in the trunk.
Mounting it across the trunk entry like I had in my S-Class Merc it just gets in the way.
Mounting it further back makes it difficult to reach.
Old Dec 3, 2025 | 02:02 AM
Dusty61's Avatar
Dusty61
Just had a look on on amayama, they have the original unit, 66311-50010. Around £5 each.
Old Dec 3, 2025 | 02:25 AM
Dusty61's Avatar
Dusty61
Old Dec 3, 2025 | 06:52 AM
alextv's Avatar
alextv
Originally Posted by quinten
all the diagrams i've found are pretty crude drawings so it's hard to tell. What year is your ls?
2001 ul
jbbreeden
Jan 14, 2014 03:01 PM
bigvain31
Sep 17, 2013 04:48 PM
BPVIP
Apr 20, 2012 02:36 PM
jbbreeden
Apr 17, 2009 05:14 AM
