Looking to DIY upper control arms, any tips?
Old Nov 5, 2025 | 02:10 PM
MythrianXeras's Avatar
MythrianXeras
Default Looking to DIY upper control arms, any tips?
I've got a set of mevotech supremes that I'm planning on installing on my car (2001 non-UL with sport suspension), does anyone have advice on DIY'ing this without having to remove the struts? I'm new to this (only did brake changes and oil before) so any detailed help or explanations would be greatly appreciated. Specific questions I have: when I break free the upper ball joint, will I need to support the rest of the spindle, or tie it to something with zip ties? Also for installing this new part, do I reuse the cotter pin or replace with the new one provided by mevotech?
Also tool-wise, will regular socket on a torque wrench/breaker bar/ratchet work or would I need something specialized for such a tight space?
Thank you!
Old Nov 5, 2025 | 02:16 PM
05ls430518's Avatar
05ls430518
Thank you!
Search bar will give you all the answers
https://www.clublexus.com/forums/ls-...l-arm-diy.html
This is my install of aftermarket controller arms but has tq specs etc
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/881380-figs-front-upper-control-arms-install.html
Old Nov 5, 2025 | 02:23 PM
MythrianXeras
This is my install of aftermarket controller arms but has tq specs etc.
I've actually been using your post as reference preparing for this, my main issue currently is I can only jack the car up on one side at a time as my floor jack doesn't reach far enough to use the central jacking point. Would the process still be about the same regardless of that? Also, I was going to measure the distance from the center of the wheel to the wheel arch before jacking it and then jack the hub up to that same measured distance before torquing the bolts, would that be sufficient?
I also don't know how much of a complication the sport suspension adds because it seems to ride about an inch or two lower than a regular one.
Old Nov 5, 2025 | 02:57 PM
05ls430518's Avatar
05ls430518
I did that exact tutorial by jacking up one side at a time so no worries there. You don't not need to cycle the suspension or anything of that nature just throw the arms on tq all the bolts to proper spec. I had to cycle my suspension due to all the aftermarket arms bushings etc my vehicle had it was called for by figs engineering. The sport suspension will not have add complications same as normal 430.
Old Nov 5, 2025 | 04:17 PM
bradland's Avatar
bradland
This This
14mm extra long ratcheting box wrench will pay for itself in time savings as well as anti headache meds.
nickderosa
May 17, 2020 08:49 PM
Sportznuts
Nov 14, 2019 01:18 PM
Lex2sea
Suspension and Brakes
Nov 12, 2014 06:39 PM
GS4hunnit
Jun 29, 2013 11:00 AM
Farino81
Jun 10, 2009 06:28 PM
