Jerking Transmission
Old Jul 5, 2025 | 04:30 PM
step430's Avatar
step430
Default Jerking Transmission
Hey forum, I was wondering if cleaning/changing my transmission gasket and filter plus a drain and fill would stop my transmission from jerking into gear. No codes btw
context: if my transmission is cold it’ll jerk pretty abruptly, if not cold it’ll have a little to no jerk. If I do some baby revs in neutral and put it into gear, it’ll still jerk a bit.
other than that. The car runs pretty good and I could drive 60 miles just cruising.
overall. I was just wondering if doing those precautions could eliminate the jerking or would if it’s the actual transmission itself that would need replacing (praying it isn’t) Thank you!
01 ls430 UL
Old Jul 5, 2025 | 08:03 PM
LowkeyLS's Avatar
LowkeyLS
Does it jerk when slowing down, ie:downshifting from 3rd to 2nd, and 2nd to 1st?
Old Jul 5, 2025 | 09:52 PM
Oro's Avatar
Oro
Please whatever you do, DO NOT tell us how many miles are on it, the service/use history, or if the fluid has any known change history.
Obviously relevant details like that make it far too easy to help with advice, and we like the challenge.
Old Jul 5, 2025 | 10:13 PM
step430's Avatar
step430
Just you saying that makes me nervous haha but if you guys need the mileage or anything don’t be afraid the ask
Old Jul 5, 2025 | 10:14 PM
step430's Avatar
step430
Nope it does not
Old Jul 5, 2025 | 11:26 PM
Oro's Avatar
Oro
OK - I can see you have little interest in professional or experienced advice; we’ll leave it there. If you do want some, square your question up and ping me.
There’s a sticky above labeled “MUST READ” and such. Give it a try.
Old Jul 6, 2025 | 02:27 AM
05ls430518's Avatar
05ls430518
01 ls430 UL
Your trans is slipping and you need a new one I am assuming you have 150k and up on the trans.
Old Jul 7, 2025 | 12:29 AM
step430's Avatar
step430
yeah 160k that’s kinda rough hearing now… how long do you think I have until it dies out?
Old Jul 7, 2025 | 12:59 AM
BigBoomer's Avatar
BigBoomer
All transmissions jerk a little when you go from Neutral to Drive (or Reverse) because you are going from an unloaded condition to a loaded condition. The RPM drops at the same time.
If your transmission drives fine otherwise, I would have the drive shaft donuts (37511-30020 COUPLING, FLEXIBLE) inspected as those can cause a more "violent" jerk than normal when they are dying.
Old Jul 7, 2025 | 10:25 AM
step430's Avatar
step430
I never thought about checking my drive shaft donuts but thank you so much for the info! I just don’t get how or why the car would jerk when cold rather than warm when it’s in neutral to drive/reverse If it’s just the drive shaft couplings?
Old Jul 7, 2025 | 12:36 PM
BigBoomer's Avatar
BigBoomer
If it doesn't do it when warm, then it probably isn't the donuts. Sorry, I missed that bit.
Old Jul 7, 2025 | 12:48 PM
05ls430518's Avatar
05ls430518
It varies could be today could be 2-3 years from now cars are weird its hard to predict unless tearing down the item, to get diffinitive answers. Just baby the car maybe add a transmission cooler. At that mileage and age I would not touch the transmission fluid or filter especially if its already acting up.
Lexus-SSA
Hybrid Technology
Aug 2, 2023 05:20 AM
ready305
NX - 1st Gen (2015-2021)
Jul 13, 2023 07:59 PM
haitianb0i
Jan 25, 2016 06:04 PM
KrazeMatik
Jul 17, 2007 09:22 PM
