Hard downshift
Old Mar 18, 2025 | 07:25 PM
djinnandjuice's Avatar
djinnandjuice
10th Gear
Default Hard downshift
I have an 01-03 ls430 that recently started having hard downshifts from 3-2 and 2-1. The chassis and transmission have 226,000 miles, the engine has approx. 130,000. I know this is a fairly prevalent issue for the 04-06 models but upon doing research I have seen relatively little about the 01-03 models. I do know that the new engine in the vehicle has the screw-type PCV valve which I believe would indicate the engine is from an 03 likely. I was wondering if having the ECM looked at by SIA or a similar company would be the best thing to do at this point, the LS has not failed me so far and it would be disappointing to find out the transmission itself is bad. Also thought I should add the engine swap was done by the previous owner. Any and all help and advice would be much appreciated, I love this car and want to keep during it for many years to come
Old Mar 19, 2025 | 11:13 AM
weldthedif's Avatar
weldthedif
i would consult with SIA, they are the experts on this issue
Old Mar 19, 2025 | 05:56 PM
LS430Lexus's Avatar
LS430Lexus
I would have it looked at. Search the forum and Google, SIA is the most reasonable but service can be spotty. Tanin in Minnesota? is good. A west coast outfit has also had positive comments, I believe its Quantum. Their are several others, including some who list the repair on Ebay. I used Relentless in Dallas with great results but their prices have increased. Make some calls, ask about turnaround time and warranties. A very worthwhile repair.
Old Apr 2, 2025 | 04:01 PM
Schroeder79's Avatar
Schroeder79
3rd Gear
One thing I noticed with mine is that the neutral safety switch or the prndl switch on the side of the transmission was slightly out of adjustment. This would cause a hard downshift into first. We noticed by the D light on the dash being off while in drive.
Old Apr 3, 2025 | 02:34 AM
RickRod's Avatar
RickRod
Mostly the ECM. It controls the engine and the automatic transmission. I have serviced so many of those LS430 ECMs that I would say that chances are 90% or more that the ECM is either the culprit or part of it. In fact, from the Lexus brand, those are the ones that fail the most when it is about the transmission. The same as for the 2001-2005 Toyota Rav4, Sienna, Camry, and Higlander that come here for service all the time.
I would suggest looking for an ECM repair shop. The circuit must be repaired and the adaptive memory for the transmission cleared, so it starts relearning from zero once the ECM is reinstalled and the car driven.
Old Apr 4, 2025 | 05:24 PM
V8_Fan's Avatar
V8_Fan
Sounds like the ECU. I had exactly the same problem, sent the ECU to Josh at Relentless Motorsports near Dallas, TX.
Old May 20, 2025 | 12:24 PM
djinnandjuice
10th Gear
Default Update
Since initially posting I sent the ECM to SIA to have it inspected to see if it was the culprit of my downshift issue, I was told by them that it is in fact not the issue, the codes on the car are a p0420 and a p0430. I called Bell Lexus for further instruction and they told me they could diagnose the car for 200 and that the catalysts could be affecting how it runs, is there a possibility of it being a transmission solenoid despite the fact that I do not have a code? I want to be as methodical as I can be so I can refrain from firing the parts cannon
Old May 21, 2025 | 01:11 AM
BigBoomer's Avatar
BigBoomer
P0420 and P0430 are normally indicative of a leak in the exhaust between the CAT and the downstream O2 sensor. The leak sucks in fresh air so the O2 sensors register too much Oxygen and trigger a fault code.
However, you don't know what happened to make the previous owner replace the engine, so could be CAT issues.
I would get the exhaust checked out for any leaks and fix those to get rid of the P0420/430 codes before doing anything else, as bad data fed to the ECU can cause harsh shifting and weird engine behaviour.
Old Jun 11, 2025 | 06:26 PM
TaninAuto's Avatar
TaninAuto
Sponsor
We are now performing this 2004-2005 LS430 ECU repair. We also include complimentary ECU software updating in conjunction with our on-board repairs.
If you purchased a used ECU we also have the ability to write your VIN to the ECU to eliminate the P0630 VIN mismatch.
https://taninautoelectronix.com/prod...ough-shifting/
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
https://taninjdm.com/
Our Lexus LS430 Dealership
demigure
Sep 1, 2024 05:52 PM
bladest
Dec 9, 2022 05:48 PM
scottbrenh
Feb 23, 2017 04:09 PM
b99flick
20
Sep 25, 2010 06:20 PM
