Footwell led light?
Subscribe
Jan 12, 2025 | 09:33 AM
Hello
04 Ls430. The foot led light once opened from it's bclacis a led soldered on a circuit board. Is that a 12v led? I have a new 12v led. Can I just solder if to the incoming wire red and black and remove the little circuit board? As a test it worked.
I messed up the little circuit board. So wondering if it's ok to wire a 12v led directly.
Can any one look up that original foot led (its whole harness with the bulb and a connector). Pictures attached
Reply 0
Jan 12, 2025 | 12:59 PM
No LED is 12 volts they are generally 1.5-3.2 volts depending on colour, power and other factors. The first picture is the replacement LED?
Reply 0
Jan 12, 2025 | 02:12 PM
No, This is what
when you wire 12v directly to the LED. Watch the video at 1:21.
The tiny circuit board has two resistors and a zener diode.
Reply 0
Jan 13, 2025 | 05:07 PM
Quote: No LED is 12 volts they are generally 1.5-3.2 volts depending on colour, power and other factors. The first picture is the replacement LED?
The first picture is the original factory led soldered on the little board.
I did order 12v rated bare Leds. Now they may have something inside them that reduces the voltage but rated for 12v input. I got both 3mm and 5mm to try.
So can these be connected directly?
Reply 0
Jan 13, 2025 | 05:54 PM
Looks like you got LEDs with built in resistor so that PCB will have to be bypassed.
Reply 0
Subscribe
