Code p0136 help
Old Jan 3, 2025 | 02:52 PM
ahall7070's Avatar
ahall7070
1st Gear
Default Code p0136 help
Hi guys,
I have a persistent P0136 code.
Initially, the code came on while driving, coupled with an evap incorrect purge flow (p0441 I believe) code. The car has had the p0441 code before, as it had popped the evap line off the filter in the engine bay once or twice before this. I mention this for context in case it matters.
I went ahead and installed a new bank 1 downstream O2 sensor to deal with the p0136 and a new evap filter and some new evap hose to replace the cracked and dry rotted mess there.
The car did not throw a code on my way to work this morning (~16mi one way), and waited till about half way home this afternoon to throw the p0136 again. The wiring looked good while I was installing the new Denso sensor. Could there be a fuse or something causing this issue?
Thanks!
kylep113
Apr 9, 2024 03:31 PM
Kybball#1
GS F (2016-present)
Dec 5, 2022 02:39 AM
Gs400DTX
Mar 31, 2021 06:42 PM
Talapo
May 15, 2017 11:58 AM
imDementeD
Mar 8, 2011 01:03 PM
