Homelink replacement?
So my homelink still works as it opens the gate to my neighborhood just fine, but it's completely stopped being able to open/close the garage door (whether that door is open or not; used to be able to close it but not open presumably due to metal?).
Is there a straightforward way to replace the emitter or should I probably just live with it?
I don't know how old your garage door motors are, but LS430 homelink no longer works with modern garage door motors. There was some change in frequency around 2009 (maybe?). You need some kind of retransmitter device in the garage to use an old homelink with the modre motor. So even if you update your transmitter in the car, I believe it is outdated tech if you ever need a new garage door motor. I have a 2 car garage and simply added a 2-button remote programmed to it on my visor. Not sure if you have an old remote that came with your door motor still, but that may be easiest.
Comrade
Aug 27, 2019 09:37 PM
