Low idle
Old Sep 9, 2023 | 10:42 AM
MaxKechely's Avatar
MaxKechely
Registered User
Default Low idle
I recently took off my throttle body to clean it, I put in new PCV and vacuum hoses as well. Now I idle at around 500rpm when the car is warmed up. Any ideas?
Old Sep 9, 2023 | 10:44 AM
MaxKechely's Avatar
MaxKechely
Registered User
Before this my idle was around 800rpm, there also was a bit of coolant in the bottom on the intake manifold but I cleaned it out if that matters.
Old Sep 9, 2023 | 06:36 PM
Yamae's Avatar
Yamae
A new throttle body needs to reset the ECU. A simple way to reset is to remove the battery terminal for several minutes or more. Other than this, it's better to clean the air mix passages using a compressor + a can of carbon solvent.
Old Sep 9, 2023 | 09:37 PM
MaxKechely's Avatar
MaxKechely
Registered User
Okay I will clean out the idle bypass valve again maybe it was the gasket I put on it, I already disconnected the battery for a while but I did it while the throttle was detached so I will do that again as well, thank you!
Old Sep 10, 2023 | 09:00 AM
TominPT's Avatar
TominPT
You need to clean out the two larger ports as well as the 8 little holes when you remove the little metal cover on top of the throttle body - as Yamae states. There are other posts and illustration on this especially in the LS400 forum.
Old Sep 10, 2023 | 11:39 AM
MaxKechely's Avatar
MaxKechely
Registered User
yeah I cleaned the two larger ports as well
KTGS300
Jun 10, 2018 04:05 PM
marshall2j
Oct 10, 2014 04:00 AM
hypervish
RX - 1st Gen (1999-2003)
Oct 16, 2011 10:03 AM
qha_vn
Nov 17, 2008 12:23 PM
SFFD785
Jul 10, 2007 01:09 AM
