Steering Wheel Does not Tilt Upwards
Old Jul 2, 2023 | 10:01 PM
ElRobeeter's Avatar
ElRobeeter
Default Steering Wheel Does not Tilt Upwards
Hey yall,
My steering wheel tilt no longer works. No matter how many times I press the button, it is still stuck in the lowest position. This is quite uncomfortable for me, so I was wondering what fixes there are to remedy this issue. I saw online that a new motor is about $200-$300. However, are there any other ways to manually wind the steering wheel up?
Old Jul 3, 2023 | 07:33 AM
TominPT's Avatar
TominPT
https://www.clublexus.com/forums/ls-...placement.html
Old Jul 3, 2023 | 10:37 AM
intermec's Avatar
intermec
Originally Posted by ElRobeeter
Hey yall,
Both motors are not working on my car. I did manually adjust the steering wheel up down position. You need to remove the steering column cover, loosen the bolt to rotate the motor. Pretty straightforward.
Old Jul 4, 2023 | 03:03 AM
BigBoomer's Avatar
BigBoomer
The tilt motor on mine has become weak and after recent front wheel hub replacements the vertically challenged mechanic lowered it all the way so he could test drive it. When I went to get in (6'4" of me) I couldn't adjust it back up. The telescope still worked fine though.
I managed to drive it home and then found a video online that showed removing the steering column covers. Once inside tried lubing the shaft but that made little difference. However, I could get some pliers on the end of the tilt shaft and rotate it whilst pushing up on the tilt button. Once it was in the position I wanted I refitted the covers and have left it like that as I never need to adjust it. Some day I will replace the motor but it's not urgent.
RiceBanana
RX - 4th Gen (2016-2022)
Nov 20, 2021 01:56 PM
OldLexusGy
Jun 7, 2017 07:46 AM
jay-b
Apr 10, 2015 07:12 AM
e-man
Sep 11, 2007 11:55 PM
