Low Tire error
Old Apr 19, 2023 | 10:15 AM
jls667's Avatar
jls667
Default Low Tire error
Do other people get this Low Tire error frequently? My tires are all at the correct psi. Any suggestions?
John
Old Apr 19, 2023 | 07:39 PM
ExiledWolf84's Avatar
ExiledWolf84
Never seen it in my 2002.... Not sure If it even has it in 2002's...
Unless someone can correct me, I don't believe the LS430 uses tire sensors, but makes an estimate on tire pressure based on rotational readings from the ABS. You probably need to initialize the system after setting pressures correctly using the button under the driver's side dash board.
Old Apr 20, 2023 | 01:56 AM
BigBoomer's Avatar
BigBoomer
You need to set your tyre pressures to what you want them to be.
Then once all 4 are set turn the ignition on (but don't start the car) and press and hold the TPS Reset button until it beeps and shows the Reset on the instruments.
Once done, Over the next 60 or so miles it will learn the rolling radius of your tyres and should only show the warning if one of them gets low.
You will need to repeat this process every time you get new tyres or change your tyre pressures, but it only takes a few seconds.
Old Apr 24, 2023 | 05:47 AM
jls667's Avatar
jls667
Default Reset button
I pressed the reset button, but the error came back after driving.
Old Apr 25, 2023 | 12:57 AM
BigBoomer's Avatar
BigBoomer
In that case you have different rolling radii on one or more of your tyres.
Do you have different size wheels/tyres or even mixed brand tyres on the car.
The system is detecting a serious difference between the rolling radius of one of the tyres for some reason.
It could also be a failed sensor but that normally throws a different error.
Old Apr 25, 2023 | 09:07 PM
430SLOwner's Avatar
430SLOwner
John
This may not be your issue, but doing the below will reset it, as you may likely already know....
Tire pressure warning system must be initialized after tires or wheels have been replaced or rotated, or after adjusting tire pressure.
Park the vehicle with the parking brake applied and turn the ignition switch to “LOCK”.
Adjust the pressure of all the tires to the specified level.
Turn the ignition switch on.*
Push and hold the reset switch until “Pressure Initial” appears in the multi-information display.**
Drive your vehicle for more than one hour or at speeds of 19 mph (30 km/h) or over.
If you make a mistake in the middle of initialization, perform the operation again from the beginning.
*:If “Low Tire” appears in the multi-information display, push the “RESET” switch for a few seconds and make sure the warning message disappears.
**:If “Pressure Initial” does not appear when the reset switch is held down, the system may be malfunctioning.
Old Apr 26, 2023 | 07:52 AM
TominPT's Avatar
TominPT
When I had a similar issue pop up in my daily driver (VW), I actually had a slow leak in one tire. Rule that possibility out.
Old May 5, 2023 | 08:01 PM
funcrusher's Avatar
funcrusher
This happened to me about a couple of months ago. Couldn’t patch the tire so got a new one and reset the dash notification. I’ve gotten it a few times since then and it’s getting on my nerves. I’ll reset it and get it back a week or 2 later!
Old May 6, 2023 | 03:30 AM
BigBoomer's Avatar
BigBoomer
When you reset the TPS, do you also check the pressures before you reset and are they close to what you last set them to?
Do you have the same model tyres on all 4 corners?
If the warning is showing it is because the rolling radius of at least one tyre has decreased more than the others.
I had similar when I replaced a punctured tyre with a part worn of a different brand and I think it was because that tyre warmed up at a different rate to the other 3.
Old May 6, 2023 | 12:55 PM
funcrusher's Avatar
funcrusher
The new tire is a different brand than the rest. I’m going to check the pressure on all 4 and set them to exactly 35 if the notification comes up again (before resetting it)
Old May 8, 2023 | 06:28 AM
Pam0705's Avatar
Pam0705
4th Gear
Default Check spare in trunk
We went nuts checking tires...lexus service dept said the trunk tire is also measured.
Old May 15, 2023 | 12:57 AM
jls667's Avatar
jls667
When I brought my car into the local mechanic, he somehow reset the low tire error. I thought I had done the suggestions.
Old May 15, 2023 | 05:58 AM
BigBoomer's Avatar
BigBoomer
Trunk tyre cannot be measured as the LS430 system (Indirect TPMS) does not detect pressure directly, and even if it did Direct TPMS sensors are not activated until the wheel starts to rotate, which the spare never does.
The LS430 system reads the rolling radius of each tyre relative to the others via the wheel speed (ABS) sensors and if the rolling radius decreases relative to the others, then it alerts you.
When you reset the system you then need to drive for at least an hour for it to learn the new relative rolling radius of each wheel.
Old Jul 20, 2023 | 07:59 PM
jls667's Avatar
jls667
That was a good explaination of the tire sensor in an LS430. When I reset the low tire light, it always comes back within a few days. I know the tires have the correct pressure.
Old Jul 21, 2023 | 12:58 AM
BigBoomer's Avatar
BigBoomer
The warning means that the rolling radius of one or more tyres has decreased since the last reset/learn.
This can be caused by a decrease in pressure, or a tyre that changes pressure when it warms up in a different way from the others, caused by having different tyres fitted.
More often it's because people don't follow the Reset procedure correctly.
It could also be caused by damaged/defective wheel speed sensors since that is what it uses to calculate the relative rolling radii of the tyres.
