High Pitched whining noise on cold start
Old Mar 2, 2023 | 04:30 AM
Freddy12's Avatar
Freddy12
Default High Pitched whining noise on cold start
Hi all, I started my 2002 LS 430 yesterday. The revs seemed unusually faster for a cold start and there was an almost eerie high pitched sort of whining noise which went away after a short while after I gently pressed on accelerator. I switched off the engine then back on and it was no longer there. Car is parked indoors but it has been quite cold lately in Toronto. Anyone ever had this? Freaked me out a bit
Thanks for listening
Old Mar 2, 2023 | 04:53 AM
JacobsDad's Avatar
JacobsDad
Ok......on a cold start, the SAI pump turns on for a short time. It sucks in air thru it's tiny air filter. Perhaps the whining you hear is the result of air getting sucked thru a this filter.
Old Mar 2, 2023 | 04:56 AM
Freddy12's Avatar
Freddy12
Thanks JacobsDad, I'll keep listening and watching..Car drove fine and noise didn't re-occur. Very sensitive to noise that can spell $$$$$..
Cheers!
Old Jan 16, 2024 | 02:12 PM
Bocatrip's Avatar
Bocatrip
Cheers!
Had the same noise this morning that went away after a few minutes. A very wierd high pitch whine. Did you ever resolve the noise and find out what it was?
Old Jan 16, 2024 | 02:16 PM
Freddy12's Avatar
Freddy12
Never had it again after that first and only time and hopefully it won't repeat. But we are in extreme cold again here in Toronto so will see if it returns
Old Jan 16, 2024 | 02:24 PM
In extreme cold alternators can make some gnarly noises especially the brushes.
Old Jan 16, 2024 | 02:33 PM
Freddy12's Avatar
Freddy12
I did have to change my alternator mid-year so this may have been a possible cause but the failure occurred many months after I experienced the noise. So many variables that it's hard to isolate a specific reason and the older the vehicle the more likely for an issue to arise
Old Jan 16, 2024 | 02:40 PM
I wouldn't worry about it, in very cold weather sealed bearings can be very noisy. Alternators, tensioners and the like. Alternator brushes in my Lexus buzz for about 10 seconds on a very cold start it sounds like something is going to blow up.
Old Jan 16, 2024 | 02:57 PM
Bocatrip's Avatar
Bocatrip
I can't say that cold weather was the factor here in Florida when the morning temp was near 70 degrees. Yes, it sounds like a bearing and it did go away within a few minutes. I guess I'll keep on eye on it and see if it returns. It's hard to stick a stethoscope in the tight engine compartment while the car is running. That brave I am not!
Old Jan 16, 2024 | 03:39 PM
Plastic tube works well, if it gets caught in something rotating no big deal.
Old Jan 16, 2024 | 07:51 PM
Bocatrip's Avatar
Bocatrip
. I thought that old wooden broomstick method was also effective in finding bearing noises.
Old Jan 16, 2024 | 10:09 PM
ExiledWolf84's Avatar
ExiledWolf84
Seems to me that power steering pumps always make racket when they are fired up when it's super cold out. It got to -17F here in Colorado last night, which caused those exact symptoms you are describing when starting things up.
Old Jan 16, 2024 | 10:14 PM
None of the methods are effective. I've seen many people try they declare X part is bad and are usually wrong, sound travels though the engine readily. A bad alternator is easy put a tube on that you'll hear the problem. Rest of the engine not so much.
Old Jan 18, 2024 | 03:57 AM
05ls430518's Avatar
05ls430518
I had a crazy high pitched whine once or twice on cold start then a almost a month later my alternator died while driving, this was literally a week ago. I am pretty sure it's the alternator announcing its imminent failure.
Toyota/Lexus PS pumps are always loud in general does not mean anything as the pumps especially on the LS430, SC430, GX etc is very robust and they seldom ever fail even with 0 fluid changes/no maintenance to them.
violetc
Sep 9, 2017 12:57 PM
MartysRX
RX - 3rd Gen (2010-2015)
Mar 18, 2013 05:03 PM
kyo7878
Hybrid Technology
Feb 15, 2011 07:57 AM
hlevin
Nov 4, 2009 08:04 PM
bobspeal
Nov 8, 2007 04:30 AM
