Swapping 1997a/c gps to stand alone controller 98-00
New to the page and first time Celsior owner from New Zealand
I have picked up a tidy 1997 Celsior with super low kms the car is immaculate. I am trying to replace the all in one gps/tv/a/c unit with a stand alone a/c controller sand to run a headunit below in a double din.
I am a builder so my car/wiring skills are not the best so iv been reading threads etc to try figure out what bits I need but nothing directly answers my questions.
I have removed the unit that was working completely fine. Tried a stand alone a/c controller out of a mates 1995 nothing happened at all nothing lit up.
went online googled asked a few questions and came to conclusion I needed a unit out of a newer model not older I found a tidy unit out of Japan with the controller coming out of a 1998
New 1998 controller
98 controller
Current unit out of my 1997 ucf21
Back if new unit
Back few of original unit
If this is any use in helping
I received the unit yesterday put the unit up in place plugged it in and all the lights on the interface lit up and the clock up the top was reading clear as day but nothing else was just illuminated. The demister button however was flashing slowly with orange indicator.
where do I go from here boys? Do I have the wrong unit again or what.. Help! Any help would be great pictures of which wires etc need to be cut spliced removed would be awesome.
I no I’m not the first and won’t be last that is trying to complete this.
Edit
the non-nav HVAC controller should bolt up to the car and work just fine - at least there has been success with those of us stateside in the US. looking at your connectors, they are all the same too so this should be the case. are you certain the new unit was indeed working?
FWIW, the radio harness from a nav car will not work with a non-nav factory headunit so you would have to go aftermarket for that.
more:
https://www.clublexus.com/forums/ls-...onversion.html
more:
Potentially I need to buy this instead?
here is a 95-97, note the clock is above and part of the vents (should be the same for RHD):
versus 98-00:
There was a big design change in August 97 implementing a new bus system called BEAN and there is no compatibility between the units of before and after although it looks quite similar. The internal circuits are different. An enthusiast whom I know tried to use units for a 98 to his 97 analyzing and modifying circuits spending many days and he partially succeeded but finally he gave up his project. It was beyond his ability to override the new bus system BEAN.
