Seeking Knock Sensor Failure Information
Old Jan 26, 2022 | 08:12 PM
YODAONE's Avatar
YODAONE
Default Seeking Knock Sensor Failure Information
Anyone with knock sensor failure information (mileage) for LS400 model years:
1990-1994
1995-1997
1998-2000
Online information suggests knock sensors degrade over time before triggering a code..
Not easy to access or easy to replace, but failure info useful to those replacing starters.
It appears the 2004 LS400 employed an improved ring shaped sensor, instead of earlier threaded knock type,.however it does not appear to be a plug and play proposition
Thank you
Old Jan 26, 2022 | 08:59 PM
aptoslexus's Avatar
aptoslexus
1990-1994
1995-1997
1998-2000
Thank you
I don't have exact mileage, but I had one start throwing codes at around 130k, give or take. That's for a 98. I drove it for two or three years clearing the code, which would pop up once or twice a week. But having the timing retarded whenever the code popped up was really annoying, so I changed them both out. Twice. The first time with counterfeit parts, which resulted in knock sensor codes nearly every drive. You won't find a deal on knock sensors. If you find a deal, you made a mistake. If you're changing out your starter, it would be a no-brainer to change the knock sensors, if they weren't so ridiculously expensive. And they are. And you have to use factory knock sensors or you'll do the job twice. So you have to weigh the cost and ask yourself if it's worth throwing $400 at knock sensors when you're changing your starter.
Old Jan 29, 2022 | 09:57 PM
YODAONE's Avatar
YODAONE
Numerous reported, yet not fully resolved low idle issues on 1998 - 2000 LS400's..numerous contributing factors.
Am wondering if low idle on fully warm, well-maintained engine is symptomatic of diminishing capacity, but not outright failure,
of knock sensor?
OR baked knock sensor wiring in engine valley...
Our Denso knock sensors contain resistors in series?
Old Jan 30, 2022 | 06:27 PM
Yamae's Avatar
Yamae
I can answer only this question.
Most of them have a parallel resistor of a few to several hundreds K ohms. The purposes to add a resistor is to do a damping and to make it possible to check the condition of cable's open/short. The sensor itself is a ceramic resonator and it is not conductive. In order to check the cable, a paralleled resistor is needed.
Old Jan 30, 2022 | 07:43 PM
YODAONE's Avatar
YODAONE
Hi Yamae;
Unlike electrolytic capacitors, there appears scant information online regarding life expectancy of internal combustion engine knock sensors, or whether there is degradation over time or simply critical failure..
There appears a resistor in the knock sensor in parrallel (which as depicted in a generic diagram to be in series) so it is unclear whether thevresistive element value is subject to stray..or whether it is even relevant.
Precursory review online suggest sensor engine codes are triggered due to knock sensor wiring harness (rodents or high heat in engine valley degrades the wiring and makes connector shells brittle) or fluid immersing the sensors in the engine valley from engine coolant or pressure washing the engine...
Based on the number of posts, it appears knock sensor failure is more common on LS430... or perhaps I read it more there because the LS430 is intolerant of aftermarket knock sensors and a lot of counterfeit parts on Ebay and Amazon.
Someone has life test data...but who?
Old Oct 7, 2023 | 12:12 PM
Tappy's Avatar
Tappy
Do you think I should replace the knock sensor if I am not seeing any codes pop up? I will be working on the starter and I’m considering also changing the two knock sensors, but this will add $300 to the bill.
89615-12040
This is the correct part number for the knock sensor for 1999 LS400, right?
Old Oct 7, 2023 | 12:57 PM
paulo57509's Avatar
paulo57509
89615-12040
Mine were exposed when I did the starter back in April. I left them alone. However, I did replace the brittle and broken off covering on the wire harness.
Old Oct 7, 2023 | 01:13 PM
Tappy's Avatar
Tappy
Where did you get that wiring harness?
Old Oct 7, 2023 | 01:22 PM
89615-12040
Yes.
Replacing them or not is a tough call. If someone knows why they fail in some cars and not others I'd like to know, mileage doesn't seem like a good indicator.
Old Oct 7, 2023 | 01:55 PM
paulo57509's Avatar
paulo57509
It's the original harness. The factory wire covering gets brittle from heat and breaks off, leaving the wire bare.
I just covered the wire with is:
https://www.summitracing.com/search/...raid-wire-wrap
Old Oct 7, 2023 | 01:56 PM
bradland's Avatar
bradland
Originally Posted by Tappy;[url=tel:11591746
11591746[/url]]Do you think I should replace the knock sensor if I am not seeing any codes pop up? I will be working on the starter and I’m considering also changing the two knock sensors, but this will add $300 to the bill.
89615-12040
It’s really just a question of how much is your time worth.
Once you remove the intake to access the parts you’ll know.
If it took 3 hours to remove the intake it might be worth the gamble, if it took 6 maybe not…
bornking
Nov 6, 2014 07:06 PM
Bradlex
RX - 1st Gen (1999-2003)
Apr 29, 2012 06:22 PM
billy boi
Jul 15, 2005 07:14 PM
slash
Mar 5, 2005 05:48 AM
