Trac error code 51 / problem in Engine Control System
Old Nov 28, 2021 | 10:09 AM
Goesta's Avatar
Goesta
Default Trac error code 51 / problem in Engine Control System
Hello! I drive an LS400 from 94, and while driving today the check engine and "trac off" light came on. I took a wire and tried getting some error codes, none came up for the engine light, but error code 51 came up for the traction control which states "problem in Engine Control System". Seems a little vague to me. The car is really weak when I accelerate from standing still, idle is slightly uneven and low at 300-400 rpm. When letting of the gas too quickly the engine dies. I can also hear a ticking when I open the hood.
A couple of weeks ago I got the ECU changed, the car worked perfectly for a couple of weeks. So my question is, is it likely that this is an ECU problem, or should I look elsewhere? I also had the cambelt changed a while ago, is it possible it has skipped a tooth?
Old Nov 28, 2021 | 10:07 PM
Yamae's Avatar
Yamae
Sorry for your trouble. The code 51 is quite vague and the quickest way to troubleshoot would be to replace the ECU. Does the original ECU show the same symptom as now? If you are still keeping the original ECU, it would be an idea to swap but capacitors should be changed. A 94 is 27 years old and old enough to have failing QAS capacitors problem even not leaked and I'd say every old ECU is not OK any more to use without replacing them.
Old Nov 29, 2021 | 01:19 AM
Goesta's Avatar
Goesta
The old ECU is broken, doesn't work at all. Seems a little weird to me that the capacitors in the "new" ECU would break after only 2 weeks of driving. But I will open it up tonight and see if I can spot something obvious.
Would the timing belt skipping a tooth show this code and no engine code, only the light? It has happened once before and the car was running equally bad (maybe a bit worse), but I didn't check for codes that time, I let the workshop that did the job fix it.
Old Oct 31, 2025 | 07:04 AM
kbaclawski's Avatar
kbaclawski
2nd gear
Default the same problem
[QUOTE=Goesta;11172334]Stary ECU jest zepsuty, w ogóle nie działa. Wydaje mi się trochę dziwne, że kondensatory w „nowym” ECU pękły po zaledwie dwóch tygodniach jazdy. Ale rozkręcę go dziś wieczorem i zobaczę, czy uda mi się coś zauważyć.
Czy przeskok paska rozrządu o jeden ząbek sygnalizuje ten kod, a nie kod silnika, tylko kontrolkę? Zdarzyło się to już raz i samochód pracował równie źle (może trochę gorzej), ale tym razem nie sprawdzałem kodów błędów, tylko pozwoliłem warsztatowi, który to naprawił.[/QUOTE
I have the same problem, did you manage to solve the problem?
Old Oct 31, 2025 | 07:05 AM
kbaclawski's Avatar
kbaclawski
2nd gear
Default The same problem
Originally Posted by Goesta
Stary komputer sterujący (ECU) jest zepsuty i w ogóle nie działa. Wydaje mi się to trochę dziwne, że kondensatory w „nowym” komputerze sterującym (ECU) pękły po zaledwie dwóch tygodniach jazdy. Ale rozkręcę go dziś wieczorem i zobaczę, czy uda mi się coś zauważyć.
Czy przeskok paska rozrządu o jeden ząbek sygnalizuje ten kod, a nie kod silnika, tylko kontrolkę? Zdarzyło się to już raz i samochód chodził równie źle (może trochę gorzej), ale tym razem nie sprawdzałem kodów błędów, tylko pozwoliłem warsztatowi, który to naprawił.
Mam ten sam problem, czy udało Ci się go rozwiązać?
sunnybasse
Jun 1, 2017 11:09 AM
Hilux22RE
May 3, 2011 12:02 PM
redstar142
GS - 1st Gen (1993-1997)
12
Nov 23, 2004 08:01 AM
willy431@aol
Maintenance
Mar 7, 2004 06:51 PM
koolkat1973
Maintenance
Mar 29, 2002 06:10 AM
