1995 LS rack and pinion tutorial question
Old Apr 30, 2021 | 05:34 AM
blkstealthpaid4's Avatar
blkstealthpaid4
Default 1995 LS rack and pinion tutorial question
https://www.clublexus.com/forums/ls-...-tutorial.html
I need to chnage my rack and pinion.I went underneath the car to see how I would tackle.Instead of doing it his way, I am thinking
remove the bolts from the cross members and jack up the engine like I am about to change the engine mounts.Remove both sides of the tire rod ends etc
Would that not be possible?of course rempove the knuckle and pressure lines.I am thinkling jacking up the engine should give adequate space to slide it out.What do you think?
Old Apr 30, 2021 | 06:35 PM
kambam3627's Avatar
kambam3627
I don't know where the idea about lifting the engine came from and your not the first person to mention it. I removed my rack last weekend without doing anything but remove the steering columm bolt and the 2 17s holding the rack on the crossmember, but to be fair i have a lift available which always helps.
Goodluck
Old May 3, 2021 | 09:56 AM
blkstealthpaid4
Thank you.I saw another youtube member do that.What year is your car?Did your solenoid connector match the new one you installed or where you able to swap from your bad one?
Old May 3, 2021 | 09:57 AM
blkstealthpaid4
The solenoid connector that I got the junkyard looks different .I mean the rac and pinion is the same but the solenoid connector is different
ls400beast
Apr 1, 2014 11:05 AM
GearJammin
Feb 24, 2013 05:07 PM
Brownmagic
Maintenance
Jan 25, 2008 08:59 PM
