Code P0763 - Shift Solenoid C
Old Jan 13, 2020 | 10:31 AM
brewtime7's Avatar
brewtime7
Default Code P0763 - Shift Solenoid C
Hello, I need part number for Shift Solenoid C. Engine code is P0763. I cannot find searching on internet. I did replace Solenoid Assembly (part #35230-30010) a couple years ago. Is this the same part? Pic is part replaced in March 2018.
Thanks, Dan​​​​​​​
Old Jan 13, 2020 | 03:59 PM
Yamae's Avatar
Yamae
Thanks, Dan​​​​​​​
Yes, it's the shift solenoid C (part #35230-30010). But I must inform you that the code P0763 is often set when the pressure control line is clogged other than the solenoid failure itself in my past experience.
Old Jan 13, 2020 | 08:00 PM
brewtime7's Avatar
brewtime7
Thanks!! Is this an easy fix?
Old Jan 13, 2020 | 08:21 PM
valex's Avatar
valex
I had been dealing with an intermittent and then constant P0763 on my 1999 LS400 for a long time and finally changed the Solenoid about 8 months ago, problem solved
https://www.clublexus.com/forums/ls-...715-p0763.html
khalid3230
Jan 6, 2019 11:23 AM
KevinLex11
Sep 26, 2018 02:48 AM
missvorn
Feb 26, 2015 06:48 AM
imjohnphan
Apr 29, 2011 03:06 PM
elcue824
Feb 4, 2006 05:05 PM
