Help Needed - Lower Control Arms
Old Aug 23, 2018 | 07:53 PM
Banglabhai's Avatar
Banglabhai
Default Help Needed - Lower Control Arms
I have 2000 Lexus LS400 with 121K. Today I took the car for an alignment and they asked me that I need to replace the Lower control arms. I was looking for multiple threads but i found about lower ball joint.
Can you guys please help me where can I find the replacement parts and what are my choices? Can I replace the bushings only or do I need to replace the entire arms?
Thanks for your help in advance.
Old Aug 23, 2018 | 11:43 PM
AlaskanLS's Avatar
AlaskanLS
http://www.lexls.com/tutorials/suspe...flowerarm.html
Old Aug 23, 2018 | 11:48 PM
AlaskanLS's Avatar
AlaskanLS
These links will give u a clue how to replace the lower control arm. Actually scotty in the video is replacing lexus control arm.
Old Aug 24, 2018 | 05:18 AM
Banglabhai's Avatar
Banglabhai
Thanks a lot
Old Aug 24, 2018 | 05:56 AM
billydpowe's Avatar
billydpowe
I dont believe you need control arms at 127K, but here is your front end (2000) what is posted above is not your year model..
Old Aug 24, 2018 | 10:11 AM
RA40's Avatar
RA40
Super Moderator
With Billy. The higher possibility would be the strut/caster bar or lower ball joint.
Old Sep 1, 2018 | 10:31 PM
Losiracer2's Avatar
Losiracer2
If your lower bushing is no longer intact, then you have two choices, buy new lower arms, around $220 a piece at Lexus or just buy the bushing, which is around $30-40 online and press them in. I opted for the second since the metal part of the arm never fatigues or wears out. At this stage, you'll probably save a ton of money if you go buy a 12T press and do all the bushings in our cars vs. buying new upper/lower arms and strut rod arms, etc.
Old Sep 4, 2018 | 02:13 PM
Rokas's Avatar
Rokas
Good tip...
Jason12327
Sep 10, 2018 08:33 PM
Omen766
IS - 1st Gen (2001-2005)
Apr 4, 2017 10:13 PM
Bankswood
Sep 18, 2014 09:50 AM
Kharizma
Suspension and Brakes
12
Apr 9, 2006 04:04 PM
Lex2Go
Feb 12, 2004 11:20 AM
