Trans fluid exchange
Old Aug 19, 2018 | 04:36 AM
Losiracer2's Avatar
Losiracer2
what I did to nail the fluid level as before was just measure the quantity I removed and started from there. I was only about a half quart off, going off how much I splashed on the ground, so I got the level pretty close to where it was before hand.
17k miles ago, I had done 3 consecutive drain and fills at 275k and did the filter on the last drain and fill. The fluid I drained this most recent service looked perfectly fine and really pink/red, so I think it probably could've gone further but I didn't want to risk it since the tranny has pretty high mileage on it.
Old Aug 19, 2018 | 12:00 PM
DVL5WRK95's Avatar
DVL5WRK95
When you changed the filter, what were the torque specs you used for the bolts in the filter and the pan?
Old Aug 20, 2018 | 10:09 PM
Losiracer2's Avatar
Losiracer2
I don't remember, but I did use my inch-lbs 1/4" torque wrench for both, so it wasn't very much torque at all. I used a traditional tranny pan gasket for replacement, luckily I didn't have to clean up any old FIPG on the flanges as the previous owner had done an SL lockup solenoid recently, which I replaced along with this service since I was getting a P0770 and shuddering when coming to a stop.
Old Aug 23, 2018 | 09:44 AM
DVL5WRK95's Avatar
DVL5WRK95
I found the torque specs since I picked up the manual. I’ll post them later. Haven’t had a chance to remove my pan yet since I found out the replacement solenoids I have don’t have the correct bracket.
colenzae
RX - 1st Gen (1999-2003)
May 22, 2016 02:36 PM
gadgeeets
Performance
Apr 4, 2007 07:10 PM
LazyAlex
Performance
Dec 16, 2006 10:32 AM
STONER
Performance
Apr 20, 2006 03:41 PM
Bobk528
16
Sep 26, 2005 07:34 PM
