1990 - Throttle Flat Spot
Old Mar 29, 2018 | 09:34 PM
Moarpower's Avatar
Moarpower
Default 1990 - Throttle Flat Spot
Hi guys.
My 1990 UCF10 has had most if not all engine maintenance carried out.
Idles and runs beautifully. HOWEVER - There is a flat spot at the very start of the throttle. With gradual acceleration it is not there, only when tapping the throttle. It is flat for a short moment then picks up revs as normal and revs great through the rest of the range.
Any ideas? I was thinking maybe TPS?
NOTE- After doing all the hose and line deletes, the trac light is on, but that was apparent way before this has occurred.
Old Mar 29, 2018 | 11:33 PM
YODAONE's Avatar
YODAONE
Originally Posted by Moarpower
Hi guys.
Line deletes?? Did you check whether stored trouble code(s)?
Could be throttle position sensor.
Old Mar 30, 2018 | 02:27 AM
Moarpower's Avatar
Moarpower
No codes stored. Just the PS line and a couple vacuum lines. It runs great. Idles lovely. Just that little spot right at the start as the throttle opens quickly.
Old Mar 31, 2018 | 10:35 AM
Moarpower's Avatar
Moarpower
Any ideas or tips on how to check the tps?
Old Mar 31, 2018 | 11:09 AM
bradland's Avatar
bradland
Is there any slack in the throttle cable? A 1990 model has had PLENTY of time to stretch...
It might just need adjusted.
Old Mar 31, 2018 | 02:26 PM
RA40's Avatar
RA40
Super Moderator
+1 that is one area to check.
Old Mar 31, 2018 | 03:47 PM
YODAONE's Avatar
YODAONE
The TPS has two resistive tracks....so a 4 pin connector..one pair pins with ascending resistance value and the second pair of pins with descending resistance value.
Use an ohm meter to check resistance as you slowly move the TPS through it's sweep....resistance readings should increase or decrease linearly.
If you hear grinding noise or actuator lever displays excessive side play (due to worn plastic bearing) probably time to swap it out...
I believe early LS400's used more than one TPS' depending if TRAC and cruise control..
Old Mar 31, 2018 | 09:12 PM
Moarpower's Avatar
Moarpower
No slack in the cable. Throttle opens smooth, just not getting fuel at the fist second.
I will test the TPS today. Happy easter.
Helogadget
Mar 14, 2025 02:35 AM
oneforu2c
May 16, 2022 10:18 AM
AlaskanLS
26
Feb 27, 2017 02:52 PM
jcp
Feb 16, 2014 02:32 PM
Suneet
12
Jun 7, 2007 11:33 PM
