Omg!! Code p1349
Old Oct 19, 2014 | 07:32 PM
billydpowe's Avatar
billydpowe
PD 1349 is for left bank
Old Oct 20, 2014 | 06:44 PM
DadLife's Avatar
DadLife
Originally Posted by PureDrifter
did he replace ONE oil control valve or TWO?
Since there are a pair.. so a Pair of screens, a Pair of valves, and a Pair of harness plugs.
yeah just replaced both ocv filter aka screens... i don't think both ocv solenoids since it was calling for bank 1(left bank/driver side) I even ask the dealer what they say bank 1 is and they said driver side. After changing ocv filters the code didn't come back as quick, it actually took 16 miles.
I may just change the other one as well, the timing sensors looked good as well.
damn this is frustrating.
thank you again for all the in-put. Ill keep you post on what it takes to finally fix it.
Old Oct 20, 2014 | 08:05 PM
billydpowe's Avatar
billydpowe
dad, I am fresh out of ideas... good luck and be sure you post the FIX
Old Oct 25, 2014 | 06:35 PM
DadLife's Avatar
DadLife
Do you think that changing the ocv on passenger side (bank 2) would fix it even though it through code for driver side (bank 1) ocv?? Cause driver side has a new one.
Old Oct 25, 2014 | 07:33 PM
billydpowe's Avatar
billydpowe
no, I dont, but I went ahead and cleaned mine thinking they were the same age.... so?
Old Oct 25, 2014 | 07:50 PM
Yamae's Avatar
Yamae
You can do the stand alone test after removing it from the engine. The inner part should move nicely when the DC12V is applied to the coil. I have seen an OCV which showed the stroke smaller than normal.
rmk9785e
RX - 1st Gen (1999-2003)
Oct 5, 2017 09:46 AM
msweber97
16
Jul 20, 2014 10:11 AM
Cars1990
Mar 27, 2012 01:51 PM
