LS400 Automatic Transmission Fluid help
Old Sep 21, 2014 | 06:21 PM
SharpeAs's Avatar
SharpeAs
Question LS400 Automatic Transmission Fluid help
Can I not just top-up the auto transmission fluid? Surely this will benefit the car to some degree as I do not have the know-how & facilities to drain it?
Where on the engine is it located?
LS400 '96
Any tips much appreciated.
Old Sep 21, 2014 | 08:30 PM
RA40's Avatar
RA40
Super Moderator
Welcome to Club Lexus.
The transmission dipstick and fill tube on left hand drive models is located back by the brake booster. The dipstick is labeled "Trans Fluid". Check the color of the fluid and if it is at the proper fill level then you will not be able to add more fluid. If the fluid is black, it will need to be incrementally drained. We have discussions on how to do this.
Adding more fluid above the marked level will cause the transmission to not shift properly. Don't add any fluid to "top off". Use the specified Toyota Type IV only and replace exactly what is drained off.
Russ643
14
Jun 6, 2023 01:19 PM
ISFer
IS F (2008-2014)
14
Apr 27, 2010 11:56 AM
poicow
Mar 18, 2009 02:37 PM
gadgeeets
Performance
Apr 4, 2007 07:10 PM
