Audio system info requested
Old Sep 30, 2013 | 06:01 PM
billymild's Avatar
billymild
Finally had some time to look into the issue. My sub has broken terminals on the speaker itself. I would like to replace the sub with something else same size. I'm not looking to win audio competitions. The last 8" sub I had was a JBL and it would hit pretty hard. Sounded great in my 951. That car was a hatchback so it was all open unlike the LS which has much more sound deadening.
http://www.crutchfield.com/p_2064CWS...r-40CWS82.html
Would this sub work? From my research the stock system puts out 50 watts @ 2 ohms for the sub. If those specs are correct that sub would fit the bill perfectly.
Old Sep 30, 2013 | 08:43 PM
johnnyg66's Avatar
johnnyg66
Work yes. But you might run into my issue the sub will not fit down into the hole. Either have to mount from below or widen the hole. I didnt do either and put old sub back.
Old Sep 30, 2013 | 11:37 PM
Sc0pe's Avatar
Sc0pe
Well, if you're looking for a direct replacement, look at shallow 8" subwoofers. The one you posted, based on the specs, are pretty dead-on. Any issues you run into with mounting it can be quickly taken care of with a drill (or an MDF adapter in extreme cases). I would suggest replacing the radio/subwoofer but in this scenario, you don't really want to have to replace your radio (This car is a freaking nightmare. Don't even bother with the RCA method that some people have mentioned in the past. Just bypass the amp and save yourself a day of agony.) but it does allow for that Bluetooth which you seem to be interested in. The head unit I am installing (well, finished installing) comes with Bluetooth and a cute little microphone (which I positioned as depicted in the image below [credits to: anarchyx34]). PM me if you want any more info.
Old Oct 1, 2013 | 05:56 AM
billymild's Avatar
billymild
On LexLS tutorial he uses a kicker sub similar to this one. He cut off the mounting ring from the stock sub and it worked without any MDF.
Old Oct 1, 2013 | 09:58 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
keep in mind any replacement of the stock sub will require a sub made to work in free air/IB applications.
Old Oct 1, 2013 | 06:40 PM
billymild's Avatar
billymild
That Kicker is made for free air operation.
Old Oct 1, 2013 | 07:19 PM
Lavrishevo's Avatar
Lavrishevo
At least you don't have to deal with the 16 ohm ML sub like I have too. eBay was good to me but still...
Old Oct 1, 2013 | 07:40 PM
Sc0pe's Avatar
Sc0pe
This. Or, you could build a "deck box" which has been done in the "Audio set up thread", though it looks kind of odd...
Bylan
Sep 18, 2022 01:54 AM
Jlacck
22
Dec 10, 2013 07:28 AM
Husker1
15
Aug 24, 2011 10:17 AM
SWEETSOUND2001
Jan 29, 2002 07:47 PM
SWEETSOUND2001
Jan 21, 2002 04:55 PM
