89 Celsior - program remote key
Old Oct 14, 2012 | 07:57 PM
YAK00Z's Avatar
YAK00Z
Default 89 Celsior - program remote key
Hi. Im just trying to find the steps on programming a remote lock/unlock key to my 89 celsior. Ive replaced the battery in the key but still not working. Its a key with a little black button on the side which has door lock/unlock written on the back. Thanks.
Old Oct 15, 2012 | 01:54 AM
Boob's Avatar
Boob
Old Oct 15, 2012 | 04:01 AM
Kansas's Avatar
Kansas
There is no "programming" to perform on the North American gen 1 (90-94) LS400 keys. Replacement keys come with a matching ROM chip that inserts into a receiver in the trunk.
Old Oct 7, 2014 | 02:08 PM
smix's Avatar
smix
Where is the receiver in the trunk?
Old Oct 10, 2014 | 12:35 PM
steve2006's Avatar
steve2006
Remove the panel where the toolbox is located on the driver's side in the trunk ( various plastic clips and bolts inside toolbox to remove) and the remote ECU is located behind it opposite the trunk hinge.
Also check the switch marked "remote" below the mirror position switch is switched to "on"
Old Dec 31, 2014 | 10:56 PM
oldskewel's Avatar
oldskewel
I've got 3 or 4 one-button remote keys that - as far as I know - came with my '91 LS400 (in-laws were original owners).
One of them works pretty much fine - maybe 20% of the time I need to press multiple times to get it to work, but other than that it is fine.
The others do not work at all as remotes - even with fresh batteries, but they will open doors mechanically and start the car.
Since there is "no programming" does this mean there is nothing I can do to get them to work?
I don't know if they've been through the laundry and electronically ruined or what. They all look fine, except that the only one that actually works is obviously getting fairly worn out.
chuck58
Jul 21, 2018 06:24 PM
RG250
CL of Southern California
Apr 30, 2012 03:19 AM
RG250
Apr 27, 2012 11:30 AM
polluxtroy
Jan 25, 2012 11:38 AM
jwlane
Jun 1, 2003 06:55 PM
