sudden oil loss??
Old Aug 30, 2012 | 05:49 PM
ccorogers's Avatar
ccorogers
Default sudden oil loss??
Please help fellow LEXUS brothers. My 96 LS has 204K on the odometer and runs like a sewing machine; today on my way home the oil light with the wavy lines came on, and the a red colored oil light was flickering on and off. I got home and checked the oil and the stick was bone dry. I added about two quarts of oil and the stick showed it was full. I left for work and the orange oil light with the wavy lines came back on. and on the drive way there is a pretty big stain on the concrete were it had leaked. does sound like a rear main? I want to drive it as long as possible and thank you for your help......
Old Aug 30, 2012 | 05:57 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Well, if the oil drain plug is still there, I would assume it's a rear leak...
Old Aug 30, 2012 | 06:03 PM
Lavrishevo's Avatar
Lavrishevo
If the plug was gone you would have lost the engine. Sounds like the main. Should be pretty easy to tell once you look up underneath it. I would not drive it much till you get it fixed.
Old Aug 30, 2012 | 06:19 PM
ccorogers's Avatar
ccorogers
I know the rear main is a giant job, how much do you estimate on labor and parts????
Old Aug 30, 2012 | 06:37 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
spray down the underside of the car, dye the oil, and find the leak. no sense in doing the RMS if its a failed sump or something like that.
Old Aug 30, 2012 | 07:57 PM
RA40's Avatar
RA40
Super Moderator
As PD mentioned. I wouldn't expect the RMS to let go that suddenly but "stuff" happens. Do you still have the engine under cover on it? If not, check the oil filter to see if it has been pierced by some road debris.
Old Aug 30, 2012 | 08:52 PM
ccorogers's Avatar
ccorogers
Default Labor guidelines?
can anyone in here give me an exact time the "books" call for labor in replacing the rear main on a 96 LS400? I have scowered the internet with no luck. I saw the seal is like 15 bucks. any help is appreciated.
Old Aug 30, 2012 | 09:16 PM
Lavrishevo's Avatar
Lavrishevo
https://www.clublexus.com/forums/5709389-post6.html
Old Aug 30, 2012 | 11:38 PM
PureDrifter
BahHumBug
CL Folding 100,000
you don't need another thread just for labor times, ask here.
merged.
Old Aug 31, 2012 | 03:44 PM
Bill Dowd's Avatar
Bill Dowd
if you find out that the rear main seal is not leaking I had to have my oil pan re-sealeed at 240,000 miles also check the oil filter that it is not loose just a thought.
LandonGs03
Jul 6, 2014 02:06 AM
Jos
Mar 24, 2013 09:09 AM
jrratty
Mar 4, 2010 08:36 PM
KingNasGS4
21
Mar 24, 2009 08:51 PM
Boz MoN
Mar 29, 2006 02:11 PM
