Rear light indicators
Old Jul 4, 2012 | 08:01 AM
Dubbayoo's Avatar
Dubbayoo
Default Rear light indicators
So I get that the dash indicator light (when lights are on) is supposed to mean a bulb is out, in this case a rear bulb. However I don't see any bulbs out, even with a weight on the brake pedal to test those too.
Does the indicator ever mean pending failure or is there really a bulb out and I just don't see it? Mine comes on when I tap the brakes (to shift out of park) whether lights are on or not, then it stays on until I shut off.
Old Jul 4, 2012 | 10:00 AM
deanshark's Avatar
deanshark
Does the indicator ever mean pending failure or is there really a bulb out and I just don't see it? Mine comes on when I tap the brakes (to shift out of park) whether lights are on or not.
If it is when you shift out of park? (Check your reverse lights) If it's when you put your foot on brakes before you shift then it may be your third brake light. Mine does it sometimes b/c of a loose connection in the bulb socket. Sometimes it works, sometimes it doesn't. (Like everything else on this car)
Old Jul 4, 2012 | 10:52 AM
johnnyg66's Avatar
johnnyg66
I know when mine started doing that i couldn't find the bad bulb. Turned out to be the harness on the passenger side. Bad socket.
Old Jul 4, 2012 | 02:22 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
remember to check the 3rd brake light on the rear deck.
Old Jul 4, 2012 | 07:46 PM
LSTex's Avatar
LSTex
+1 and change both lamps, even if they're lit. Mine were lit, but they looked dark like they were burnt or something. After changing both lamps, the trouble light went out. Evidently, the lamp resistance changes over time and kicks the trouble light on.
Old Jul 10, 2012 | 06:22 PM
Dubbayoo's Avatar
Dubbayoo
I have checked, rechecked and checked again. There is no light out back there.
Old Jul 11, 2012 | 12:52 PM
91LS400vgb's Avatar
91LS400vgb
Even if the lamps are working, the internal resistance may have changed, which forces the tail light indicator light on. Some have corrected it by replacing the high mount brake light bulbs, as PD suggested. I would try changing them first, even if they still appear to be good.
Old Jul 11, 2012 | 01:28 PM
PureDrifter
BahHumBug
CL Folding 100,000
..you did check your turn signals and reverse lights too, right?
tanvet
14
Mar 27, 2017 06:32 AM
worldforgo
Apr 2, 2011 06:53 PM
LS400_boy
16
Jan 22, 2009 01:45 PM
infra917
IS - 1st Gen (2001-2005)
Feb 23, 2007 05:56 PM
gerbjones
Aug 31, 2005 12:12 AM
