suspension probleM?
Old Oct 13, 2002 | 03:49 PM
cutecboy's Avatar
cutecboy
Unhappy suspension probleM?
recently my car start to shake when i go over 50 miles per hour the steering wheel shake and the whole car shake sometimes it stops but it definitly starts when i go over 50-60 miles per hour.. i got a alignment done.. i got the tires balanced.. yet it still does the same thing? i am thinkin it could be my tires are warped or the rim is bent.. but i highly thought it.. can anyone give me a suggestion on maybe what is wrong? axles? jointS? anythinG? i am really frustrated.. thanks alot
Old Oct 14, 2002 | 12:00 PM
SQ-LS's Avatar
SQ-LS
You might want to check your bushings and engine mounts.
It might be time to change them, I know I need to.
Old Oct 18, 2002 | 12:02 AM
cutecboy's Avatar
cutecboy
Default loule
bushinG? engine mounts? are u sure that's why my car is shaking? or maybe it is? how much would it cost for me to change those out?
Old Oct 18, 2002 | 12:35 AM
SW03ES's Avatar
SW03ES
A lot.
I remember on my dad's 98 LS he had a problem with horrible shaking at highway speed. We could never track it down until we replaced the tires, never came back.
Do you have a spare? Might wanna try swapping each wheel with it and see if you can identify the wheel that is scalloped. We had his balanced and rotated too, never helped for long.
Old Oct 18, 2002 | 03:19 PM
cutecboy's Avatar
cutecboy
Default >>>?????
Originally posted by SW03ES
A lot.
for some reason i do think its one of my rims.. just dont know why.. i mean i never ran them into anything.. or tires.. i dont know how they could have go wrong..
Old Oct 19, 2002 | 06:56 PM
rudylexus's Avatar
rudylexus
Helo,
A few months ago, i had the same problem with my ls 400 from 1998. First i put 2 new tires in the front, but the problem was not solved.
I did feel the shaking most of all in the steering wheel. So , i was very surprised when my official dealer told me the problem was on the rear wheel.
The cable of the parking brake, did not set loose on 1 wheel. So, this was activating the ABS, even without touching the brake pedal. The shaking was caused by the ABS that opend and closed the brakepads (high tempo).
After changing the cable the problem was solved.
Groetjes Rudy.
Old Oct 19, 2002 | 09:15 PM
cutecboy's Avatar
cutecboy
Originally posted by rudylexus
Helo,
Groetjes Rudy.
only the steering wheel was shaking or the whole car .. i mean i can feel it just from my feet and the chair is shaking too..
any other suggestions
Old Oct 20, 2002 | 05:32 AM
rudylexus's Avatar
rudylexus
Helo,
I supposed the whole car was shaking, but because we hold the steering wheel whith both hands, we can feel it the there the most.
Strictly speaking it was the knocking of the brakes (ABS) you could feel, but the tempo was so high, you schould say it was a heavy trembling.
Also, when i slowly start, i could hear the brakes squeak a little.
Aftherwards it make sens, but in former days, i don´t care for it.
Groetjes Rudy.
Old Oct 22, 2002 | 12:16 AM
cutecboy's Avatar
cutecboy
Helo,
Groetjes Rudy.
very interesting rudy.. i have a couple of questions.. i dont ever use my parkin brake? can the abs still cause the probleM? does ur steering wheel shake when ur going 40 mph? becuase after i go pass 50 it start shaking .. steering wheel wise.. also.. u said that ur brake squeeze as u slowly stop.. mine does the same thing and its also problems in the rear? do you have any suggestions for me? this maybe the problem.. or it maybe not.. the hand brake cable u said that need to be replaced.. please help me out... give me a advice or something
thanks
Old Oct 25, 2002 | 07:01 PM
rudylexus's Avatar
rudylexus
Sorry cuteboy, i was out of town this week,
Sometimes the trembling started at 60 km/h (33 mph), sometimes it started at 80 km/h (43 mph).
My brakes did squeeze, because they did not come loose completely. If yours squeese too, it is a serious sign it is the same cause.
Yes, for me the problem was solved afther replacing the parking brake cable. I did not replaced it myself, so i can not explain the work.
Possible some oil could set the cable also loose, i dont now. The dealer replaced mine.
Groetjes Rudy.
k954triniz
IS - 1st Gen (2001-2005)
Feb 16, 2012 04:51 PM
irokdastar
Jul 25, 2011 09:33 AM
gstracer
Aug 4, 2009 01:15 PM
Jujharoo
Suspension and Brakes
Nov 12, 2004 01:23 AM
ESES
22
Feb 27, 2003 11:21 AM
