VSC and BRAKE problem
Old Jun 18, 2010 | 04:23 AM
billydpowe's Avatar
billydpowe
go by Autozone and see if it has any codes (it is free), check all battery connections (clean), check gas cap, check for low brake fluid,
Please note that an engine malfunction disables the VSC as a failsafe measure.
If you have 1 low tire, or 1 abnormally worn tire it will play havok on the VSC.
It's related to the ABS and the individual wheel speeds....1 wheel not registering the exact right speed will kick the lights on.
When I say exact i mean it, 1% difference is enough.
By all means check the codes...but check the tires too.
mine had codes 1345 & 1354 .
Old Jun 18, 2010 | 10:44 AM
silos5's Avatar
silos5
thanks billydpowe!
I was rolling my fenders today and I had to take front calipers off, I noticed I didnt tighten bolts well last time when I was changing suspension parts May be this was a broblem. And yes, I now remebmer My front right tyre was a bit empty. Gonna fix this tomorrow and test drive it.
Old Nov 20, 2010 | 09:53 AM
billydpowe's Avatar
billydpowe
Originally Posted by silos5
thanks billydpowe!
did you get the VSC light off??
Old Nov 21, 2010 | 01:49 AM
skperformance's Avatar
skperformance
if its from take off I would say rear hubs /bearing ,. check the code .
Old Nov 21, 2010 | 06:51 AM
silos5's Avatar
silos5
what I´ve noticed: VSC light comes only when I drive slow on uneven servise (bad road).
Brake pedal shakes less and less.
these things doesnt bother me.
the only one that is left is that sometimes when I press the gas the VSC cuts the power and a "sliding car" signal comes. But I´m already used to turn the VSC off then I drive. I think the mechanics screwd some sensor when they changed the diferensial oil, or somewhere else
Old Nov 21, 2010 | 02:06 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
what tire sizes are you running...?
Old Nov 21, 2010 | 09:22 PM
bornpeace's Avatar
bornpeace
I had the same problem(trac will flash and VSC lights come on and the car will not go for few second). Solution is to check ur speed sensor, a small stretch of the wire can cause that problem. Assuming you disturb the sensor when you change your suspension. To know for sure if is the sensor, pull the ABS fuse in the engine bay fuse box. Then drive the car and see if the same problem happen. Remember when you take out the fuse ABS and VSC lights will stay on all the time. You may have to replace the sensor if is the problem.
Old Nov 22, 2010 | 07:21 AM
silos5's Avatar
silos5
225/35 and 245/35 on 19s...I know, they are a bit smaller then the OEM and this can be the problem
Old Nov 22, 2010 | 02:13 PM
PureDrifter
BahHumBug
CL Folding 100,000
if you throw the stocks on and its fine, it's not the tire sizes, then throw a VSS at it.
Old Nov 23, 2010 | 10:09 PM
whit3b0y's Avatar
whit3b0y
i got 215/40 and 235/35 19's and i dont think that is the problem.
check and see if the brake sensors have been wet. We had a big water overload a few weeks ago and i drove through standing water during this time.
about a block later the car went to limp mode. i cleared the code and nothing came up, car was fine. For 2 days, same thing, i cleared the code and its all good now
peelsSC300
Sep 8, 2015 08:21 AM
pcfall
Dec 23, 2013 05:26 PM
smokincigs
Apr 10, 2011 12:47 PM
moolman
HS 250h Model (2010-2012)
Jun 13, 2010 03:11 PM
rickjaffe
Oct 14, 2008 11:14 AM
