strutmasters suspension light disarm ?
Old 07-05-08, 04:10 PM
ninjarico
ninjarico's Avatar
Default strutmasters suspension light disarm ?
Well I finally converted the car with the strutmasters kit this morning (wasn't too bad a process actually but totally didn't do it they way they had instructed).
For anyone that has done this conversion though there is a section that says "Suspension Light Disarm" I assume "light" means the bulb in the dash cluster? Not "light" as in the opposite of heavy.
In any event it's a 93 and it says there should be a violet wire and a violet with yellow stripe wire on the connector closet to you on the ECU that need to be cut. I see the violet with yellow stripe but there is not a violet wire on that connector. On the connector farthest from me there are TWO solid violet wires and a violet with yellow stripe but I don't think that's it.
Anyone else done this before?
Oh and before and after, she still needs a lot of work but what do you expect for $500 (the springs are still settling too, they were CRAZY high when we first put them on).
BEFORE
AFTER
Old 07-05-08, 04:14 PM
L_Sport
L_Sport's Avatar
Looking good so far, so the upgrade your doing will let you adjust right hight on the fly? Sorry I am not familiar with Air Ride suspension on the LS...
Old 07-05-08, 04:17 PM
ninjarico
ninjarico's Avatar
No the stock air suspension was bad on this car (which is why in the first pics it's basically sitting on the wheels). Instead of trying to find cheap air struts we converted the whole car to a regular spring/strut setup. Strutmasters has a kit for $700 (shipped) to replace all 4 air struts.
Old 07-05-08, 05:10 PM
L_Sport
L_Sport's Avatar
damn, I thought it looked sick sittin' on the wheels LOL, so you went with regular ride hight???
Old 07-05-08, 07:36 PM
ninjarico
ninjarico's Avatar
Yeah it did look awesome but the wheels were just scrapping on the body LOL. The kit says it should look like basically stock setting for the springs after they settle. I'm not really going to mod this car just keep it simple since it was so cheap.
Old 07-05-08, 09:42 PM
L_Sport
L_Sport's Avatar
good, hope it settles, at this point a little bit high and your almost on donk status.
Old 07-06-08, 09:25 AM
ninjarico
ninjarico's Avatar
It is, it'll get better as I actually start to drive it. If not I could always throw some 22" rims on it and close up that gap
Old 07-08-08, 08:19 PM
ninjarico
ninjarico's Avatar
For anyone interested I just pulled the ECU completely and the "suspension Hi" light in the dash stopped flashing. I assume this is just as good as finding the wires that don't exist.
macjac69
08-23-14 11:10 AM
TheAzn
SC- 1st Gen (1992-2000)
03-05-13 09:26 AM
CashOverAs
01-23-09 09:59 PM
hemogoblin
11-29-07 05:36 AM
datsetup
26
11-26-05 11:43 PM
Quick Reply: strutmasters suspension light disarm ?
