Difference in LS400 years
Old Jan 18, 2002 | 12:14 PM
VQT's Avatar
VQT
Default Difference in LS400 years
Can you guy tell me the difference between 93-96 LS400?
What is a good price for a 93-94 LS400?
How many options is there on the LS?
What options should I avoid?
Thanks in Advance,
Old Jan 18, 2002 | 07:55 PM
rd8a's Avatar
rd8a
Post
some people think the first generation LS was the most well built in terms of durability of materials, but the second generation and later gets bigger and more powerful.
you should definitely avoid air suspension option because when it has problems it's very expensive to repair.
you can get realistic pricing at edmunds.com
Old Jan 19, 2002 | 06:20 AM
VQT's Avatar
VQT
Edmunds.com only give the general pricing. Its does not has realistic price.
I am asking how much do you guy value your car (Year + options). How much would you pay if you're buying a particular year...
Old Jan 19, 2002 | 05:57 PM
Erfan's Avatar
Erfan
The 1995 LS and higher have a diffrent shift **** as well, the 94 and older have the straight pull back shift **** with the button like the ES series, the newer has the little **** and the multi position shifter
Old Jan 20, 2002 | 07:01 PM
lexie's Avatar
lexie
Also '93 is about 200 pound heavier!! (stronger, more quality parts !!)
I also strongly recommand you to stay away from the air suspension option; when the air shocks fail, they cause so much to fix e.g. two front air shocks $900.00 each (parts only) two rear air shocks $700.00 (parts only) plus labor. You know what I mean
As far as the ride, '93 & '96 are almost the same. They are very quiet. Oh! '96 has more horse power; wheel base is longer so the rear passenger has 1" to 2" more leg room.
I notice the blue book value of '96 is a lot higher than '95 . There is a big price gap between the 1st & 2nd generation LS. you can check Kelly blue book price at www.kbb.com.. I suggest you offer the wholesale price (minus whatever defective parts)and don't bother with the retail price. Car dealer normally offer trade in $3000 to $4000 or more below wholesale price to customers trade in.
Old Jan 21, 2002 | 12:38 AM
Purplexed's Avatar
Purplexed
Default Check this out for more info on 95+ LS's
http://caranddriver.radicalmedia.com...exusLs400.html
Good luck.
Old Jan 21, 2002 | 06:05 AM
Erfan's Avatar
Erfan
Thanks Perplexed,
That is exactly what we were looking for! The 95+ seems to have a better header system for more torque and horsepower according to the article, its only ten more ea.. Not much of a diffrence in power ouput.
Old Jan 22, 2002 | 06:37 AM
VQT's Avatar
VQT
Default Re: Check this out for more info on 95+ LS's
Purplexed,
How's your car running? Any problems?
When you were looking for your LS400, did you see a lot of traction control, heated seats, car down there in CA?
I am planning to move back to CA soon. I wonder should I wait and look for it there or get one here in the northeast and ship it back.
Good luck.
Old Jan 22, 2002 | 09:19 AM
Purplexed's Avatar
Purplexed
Default Purchase in california
My car is running fine, no problems.
Regarding California cars. Dont think you will find much need for heated seats in california, at least not in southern california.
There are plenty of LS400's, my suggestion is to look at www.autotrader.com then put in a zip code for the area you will be in . Range of 100 miles to do the search. See what kind of selection there is in your proposed area.
Good Luck
Old Jan 22, 2002 | 10:00 AM
VQT's Avatar
VQT
Default Re: Purchase in california
Thanks Purplexed
Good Luck
handoverfi
Mar 23, 2011 08:36 PM
absolut
Oct 5, 2006 07:26 AM
LS Boy
Aug 1, 2004 10:32 PM
Sal Collaziano
89
Mar 22, 2004 11:03 AM
durightman
Jun 18, 2003 08:33 PM
