Checking engine code question...pic inside
Feb 11, 2007 | 10:20 AM
My 95 diagnostic port does not have a metal pin in the port to check the engine codes?
Feb 11, 2007 | 11:03 AM
u sure its a 96?
all 95+ LS400s have OBDII port a lil lower down...
Feb 11, 2007 | 11:16 AM
It's a 95
There is another black port next to the white one, could this be the one I need to jump?
Feb 11, 2007 | 11:20 AM
Quote:
Originally Posted by
maxgee
It's a 95
the one you want is located a bit lower and is a black plug that is trapezoidal in shape.
to read the codes ul need a OBDII code reader, either buy a cheap one ($40) or rent one for free from kragen/advance/autozone.
(take a pic lower down)
Feb 11, 2007 | 11:38 AM
This I guess is it?
Feb 11, 2007 | 12:01 PM
yep.
thats the one (on the left)
Feb 11, 2007 | 12:23 PM
Borrowed a scanner from a buddy and voila...code P0770..SHIFT SOLENOID MALFUNCTION.
hey thanks for pointing me in the right direction.
Feb 11, 2007 | 12:39 PM
np, good luck with that, sounds like a dead "A" or "B" solenoid.
Feb 11, 2007 | 07:19 PM
It drives fine, I don't feel any difference when the light came on and ECT was blinking. I guess I will drive it like this for a little bit, while I do research on the cost to fix it.
Thanks
Feb 11, 2007 | 07:35 PM
It would have been easier to just look at the end of the scan tool and look at both holes!
I remember getting a check engine light on a previous car of mine and borrowed a scanner and I accidentally erased the code off the car. I didnt even get the code number either.
Feb 20, 2007 | 07:03 AM
what do you need to jump to pull codes from an sc300...is it the same?..what pins do you jump?
Feb 21, 2007 | 08:59 AM
Search
SEARCH FIRST
but I'll help u anyhow.
troublecodes.net
later!
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
renato902
14
Jun 13, 2010 06:20 PM
JspecSC3
Oct 9, 2009 02:52 PM
VQT
Oct 9, 2007 10:52 PM
1995 ,
2001 ,
2004 ,
350i ,
430 ,
bmw ,
connector ,
diagnostic ,
es300 ,
gs430 ,
lexus ,
ls ,
ls400 ,
obd ,
port
