LS400 owners post your wheel setup
Old Apr 7, 2015 | 03:24 PM
  #2071
Stroock639's Avatar
Stroock639
Originally Posted by RA40
Depends how flush you want. 15mm on the front with the OEM 18's is fine. The rears 5-10mm more. Since tire sidewall profiles vary a bit, I'd suggest measuring it once the springs are on the car to verify how much spacer you feel appropriate with.
thanks Mike, i was actually gonna do 5mm in the front and it was the back wheels that i couldn't decide between 15 or 20mm. with these 245s i'm already 20mm up from stock and the fronts are pretty much just where i want them, but my goal is to have the fronts and backs be exactly in line with each other (each coming out to the same point)
Old Apr 7, 2015 | 10:00 PM
  #2072
b17what's Avatar
b17what
Originally Posted by sha4000
You should make sure they are high disc at the very least. There's a better chance they clear the second gen brakes.
Is that the space between where it meets the hub and the back of the spokes?
Old Apr 8, 2015 | 11:03 AM
  #2073
sha4000's Avatar
sha4000
Read this thread.
Old Apr 8, 2015 | 11:41 AM
  #2074
OKSTANCE's Avatar
OKSTANCE
Originally Posted by SonicMotor
Not yet, too swamped to bring in another project. I still have my SC, but trying to get rid of it to maybe fill in the spot with another one. Nothing gets done when you have 3 project cars LOL.
mannn i miss that car too! defiantly an inspiration when it comes to fitment
relevant
17x10.5+27 fits all the way around with the baby ufc1x brakes with no spacer
front pictured is just the stock 17x8+50 tho
Old Apr 8, 2015 | 12:26 PM
  #2075
SonicMotor's Avatar
SonicMotor
relevant
[IMG]https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1024x683/80-17020933812_07dfe48b48_b_e1146888667eb1b2209aad10f8f1ad9f4f1f0151.jpg[/IMG
Thanks bro!!! Your car is looking sweet too.
One more when it was on the rotiforms and meatier tires :P These were about the same fitment wise.
Old Apr 9, 2015 | 02:07 PM
  #2076
spo0k's Avatar
spo0k
Nissan 370Z Rays wheels. 19x9 front, 19x10 rear. Will lower soon.
Old Apr 15, 2015 | 02:23 AM
  #2077
GH5T's Avatar
GH5T
Is it at stock height now? Judging by the wheel gap the front looks a touch high but the rear looks just right. Nice wheel choice looks good.
Old Apr 15, 2015 | 08:41 AM
  #2078
Jarome's Avatar
Jarome
Default Klutch SL5
LS400 owners post your wheel setup-10264446_10152436303359490_7735753451362018877_n.jpg
LS400 owners post your wheel setup-10277794_10152436303314490_4754655465613342729_n.jpg
Old Apr 16, 2015 | 11:10 PM
  #2079
LexusJay1's Avatar
LexusJay1
Originally Posted by trukn1
Eastwind, I drive through Detroit quite often (drive tractor trailers for a living) and I have also driven my car up in that area(have relatives and friends in Detroit) with my 18's on and have had no problems at all. Agreed 17's will give you a little more cushion under the rim, but if you decide to do 18's, you will be fine as well.
wheel specs on page 1 235/40/18 18X8.5 +40 offset
sweet ride man,,where did you get the led side view mirrors?
Old Apr 22, 2015 | 05:36 AM
  #2080
spo0k's Avatar
spo0k
GH5T, yes, stock height. I assume it sits like that because the rear sags a little. I'm going to drop it, but maybe only an inch in the rear and a couple in the front. The rear tires rub a little over big bumps and dips right now, so I'll have to go with a slightly more narrow tire in the rear also.
Old Apr 30, 2015 | 05:35 PM
  #2081
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
She's so high, front megans are maxed out for height. Rears are not, yet.
Roadtrip/extended stay setup:
OEWheels Bullitt wheels,
18x9 +33 effective
255/45-18 Goodyear Eagle F1 Supercar
18x10 +42
285/40-18 Goodyear Eagle F1 Supercar
Yes I still have the Mayas
No they aren't for sale
Yes they'll go back on someday.
Old May 2, 2015 | 07:08 AM
  #2082
CELSIORAS's Avatar
CELSIORAS
Lexus LS model and year: LS400 (UCF20) 1997 12
Wheel Make & Model: WORK EUROLINES DH ("O" DISCS BOOTH)
Wheel Size (diameter and width): REAR 9X18/FRONT 8X18
Wheel Offset Front: ET38 (-21mm SPACER BEACAUSE "O" DISC ITS TO CLOSE TO BRAKE CALIPER )
Wheel Offset Rear: ET38 (-8MM SPACER, BECAUSE OUTER SHAPE OFFSET ITS SIMILAR TO FRONT WHEELS)
Tire Make and Model: PIRELLI P-ZERO / HANKOOK
Tire Size Front: 235/45/18
Tire Size Rear: 265/40/18
Suspension mods: OEM AIR
Amount of drop: MINIMAL REACALIBRATION OF OEM AIR SYSTEM (LOWEST AS POSSIBLE TO SAVE OEM AIRBAGS)
Rear fenders - remastered (not finish at moment), front - oem. Be carefuly before buyng wheels, "R" disc its diferent like "O" disc, and possible, u have a brake calipers fitment problems Next porblem - NEVER ROLLING YOUR FENDERS! Its very inmportant double sided contruction, never cuting a fenders before welding a new points of fenders. Good look.
https://www.clublexus.com/g/album/3342763
Front wheels spacer (Custom made) 21mm *, Rim size: 38ET (real ET19). outer shape = like a rear
dont doit!
newer to do it!
Old May 2, 2015 | 11:50 PM
  #2083
yoitskenn's Avatar
yoitskenn
How would a 19x10 21 / 19x11 24 sit on a 99? On coilovers. Simple roll or do i need a pull too?
Old May 3, 2015 | 02:16 AM
  #2084
CELSIORAS's Avatar
CELSIORAS
rear: 255/35 on r19 11/24 rims - need welding with contact welder rear arh before cutting center zone. No rolling if possible! .
front: 235/40 on r19 10/21 rims - no waranty about inner side (cornering and others). Outer side - wider / streched, i think - be ok if no spacer need (brake support - very wide!)
compare to my LS (look at photo of my setup for imagination) ,below - examples of my setup and your setup.
http://www.willtheyfit.com/index.php...et2=24#content
Old May 3, 2015 | 11:30 AM
  #2085
PBrown400's Avatar
PBrown400
Originally Posted by renchmonki
Varrstoen ES2's. <br/><br/>18x10.5 +12 all around.
Does anyone have any ideas on tyre sizes and what arch work has been done on this? I like this look.
