Otto Racing Strut Bar??
Thanks for the offer, I'm in the Bay Area unfortunately. The installation doesn't look too bad, I just need to get it on there tight. I'll attempt to do so tonight and take pics etc. I shouldn't need to bend the bar, its supposed to fit fine.
So once I install the Tokico's the improvements will be more dramatic? We'll see. I also received the strut bar in a condition that seemed slight used. The chrome metal bar part seems roughed up. I saw a post earlier abotu how someone had this experience with LMW, just thought I'd share mine as well.
Originally Posted by Lexkost
Suneed, If you are in SOCAL I can show you how to install it and bend it if needed.
I guess I'm a little confused on how a modified strut bar would function the same as model specific piece that has been engineered to fit that application?
On a basically stock set-up, you won't notice. When you stiffen the suspension and go to a low profile tire/wheel combo, some of the flex may show up if you are tuned to your car. There are a lot of forgiving componets in the LS to overcome though.
My post on bending te strut tower bar:
https://www.clublexus.com/forums/sho...=bending+strut
L-Tuned parts forthe UCF2X
http://www.l-tunedparts.com/model/st...id=14&cat_id=7
Nice work Mike! I think you hit it on point with this statement:
"Just count the number of turns so when you do the opposite side it is symmetrical. (Or number of pumps if using a hydraulic jack.)"
Great info, I was under the impression (and there probably is a percentage of people out there) that people were just trying to tweak a strut bar just to fit without any thoughts on how it will affect the vehicles handling.
Still not sure if I need to bend the bar. If I need to, Mike your post will definitely come in handy.
I'll try installing it tonight. Speaking of which, I need to do my struts too. It seems like installing the front struts is pretty straight forward, but doing the rear's requires a spring compressor and such. Anybody have a tutorial on this?
430keeper
Oct 24, 2014 09:34 AM
