PLEAEE HELP...Check Engine Light Code 52 "KNOCK SENSOR?"
Old Dec 24, 2004 | 06:32 AM
danreiner's Avatar
danreiner
Default PLEAEE HELP...Check Engine Light Code 52 "KNOCK SENSOR?"
When I fire up my 90 LS400 it idles fine. If I accelerate I feel a slight vaibration and my Engine light come on. I checked for codes and got # 52 which is Knock Sensor. I don't want to just replace parts "***** nilly" and have no positve results. The wires alone cost around 100. Is there one thing I should look into? Thanks, Dan
Old Dec 27, 2004 | 11:46 AM
lorenzo816's Avatar
lorenzo816
Default Knocking
If the CE light came on and the code says Knocking, you might want to see if the coils are arcing onto another surface or the plug(s) are bad..
Perform a tune-up on the car if it hasn't been done in a while.
my two cents
lorenzo
Old Jan 7, 2005 | 09:00 PM
tech237's Avatar
tech237
look at your wiring very carefully for rodent damage..If you do decide to replace your knock sensors,do the knock wires at the same time....
karan1193
Jan 7, 2015 08:33 PM
BigD
Jun 2, 2007 07:34 AM
mrtentacle
Jan 26, 2007 04:49 PM
