Cooling system refill problems
Old Jan 26, 2024 | 04:28 PM
fastegg's Avatar
fastegg
Default Cooling system refill problems
Whenever I have to refill cooling system from scratch it takes several days to get it working properly... I firstly fill via catch tank with bleed bolt removed from top of block... engine gets hot but radiator does not... let car cool down overnight... add maybe 1.5litres,,, repeat process... add more fluid...temp goes up & down making ghastly gowning & 'bubbling' sounds... maybe do this 3-4 times before cooling system fluid is stable.... clearly I'm not doing this right.... Any suggestions ?
Old Jan 26, 2024 | 05:23 PM
paulo57509's Avatar
paulo57509
Your refill procedure is entirely wrong. See attached.
File Type: pdf
Yamae's Avatar
Yamae
I use a modified funnel which is like this and I find it quicker to fill also I don't have any overheating problem using this funnel.
Old Jan 26, 2024 | 07:32 PM
deanshark's Avatar
deanshark
I used to stand there and raise the funnel a bit every once in a while to let it vent til one day I threw my funnel and it chipped off a piece, (like the cut piece on Yamae's funnel) after that, it worked perfect just leaving that funnel all the way in.
Old Jan 30, 2024 | 09:57 PM
fastegg's Avatar
fastegg
I ended up removing the top radiator hose... filling both radiator & motor.... topped it up using a funnel in the bleed bolt hole.... warmed it up... let it cool down then added a bit to the catch tank.... all good now....
wsvc206
Jul 22, 2022 02:17 PM
opisdfagjo
Oct 14, 2018 12:12 PM
glawrie
Hybrid Technology
Jul 18, 2018 03:28 PM
HB1975
IS F (2008-2014)
Mar 30, 2013 06:50 AM
schmoozer
Apr 23, 2011 06:44 PM
