Sponsored by: CARiD
headlight problem
Old Sep 24, 2003 | 06:16 PM
Din's Avatar
Din
Default headlight problem
I have HIDs in my car and one side is out i check the connection and its good, i thought it might be the balast or bulb but i switch them to the other side and it works. When I plug the conections in the plug on the side that dont work the bulb jsut flickers and stays off. Anyone know whats going on?
Old Sep 24, 2003 | 07:19 PM
rominl's Avatar
rominl
exclusive matchup
wait, that's weird... what if you keep the ballasts untouched and then changed the bulbs over and see? there gotta be one way to isolate to the ballasts or bulbs. it's hard to imagine somehting else going wrong
Old Sep 24, 2003 | 07:33 PM
Carbon J's Avatar
Carbon J
Lightbulb
Check your original connector on your headlight. The contacts might be dirty, clean with alcohol or contact cleaner
Old Sep 24, 2003 | 11:19 PM
Din's Avatar
Din
i dont think its the bulbs or ballest, where can i get contact cleaner?
Old Sep 25, 2003 | 11:49 AM
siniquezu's Avatar
siniquezu
Hope it isn't melted wires.
Old Sep 25, 2003 | 02:07 PM
mtsao's Avatar
mtsao
I second romini's idea--if you switch only the bulbs, you should be able to determine whether the problem lies in the bulb or elsewhere. Cleaning all the connections/contacts on the harnesses is a good idea and if you can, buy some 'dielectric grease' for these connections--you can buy at auto parts store, porbably even Wal-Mart. It's a white pasty conductive substance that the factory usually applies to electrical connections. Also, remember not to handle the glass part of the bulb with your bare skin.
I don't know what contact cleaner is, unless it's the stuff that I have in my eyes. You can always use sand paper or an emery board to remove debris and rust from electrical connectors, just be gentle. If you ever had a slot car set, you know what I'm talking about.
Let us know what happens after you switch the bulbs.
Mike
Old Sep 25, 2003 | 06:59 PM
Carbon J's Avatar
Carbon J
Default Contact cleaner
This type of contact cleaner you would'nt want to put in your eyes. It's main use is for cleaning electrical parts, connectors, switches, etc. It comes in a sray can and you can buy it at any Radio Shack or electronics supply store.
Old Sep 25, 2003 | 10:14 PM
Din's Avatar
Din
well it was a fuse, now for some reason one of my headlights flicker when i hit a bump sometimes.
Old Sep 25, 2003 | 11:14 PM
Carbon J's Avatar
Carbon J
Default Headlight
You've got a loose connection in your wiring. Check all wires and plugs, ex. wires joined together with those plastic connectors.
waynedog
Oct 16, 2012 07:45 AM
Tedstah
Aug 19, 2012 08:34 PM
infra917
IS - 1st Gen (2001-2005)
May 9, 2009 07:57 PM
kevs
Lighting
24
Mar 10, 2004 11:22 AM
