Sponsored by: CARiD
Need Help replacing NX200t headlights.
Old Nov 8, 2018 | 10:00 AM
SWalker123's Avatar
SWalker123
Default Need Help replacing NX200t headlights.
Hello everyone, I just registered here because I thought no one could help but lexus forums, because I am in a big mess right now.
So I was replacing headlights on 2015 Lexus NX200t, and just found out these two are different, one has xenon ballast looking thing on the top, while the other doesn't, can anyone tell me what it is? or is there any difference between them? if so, what can I do to make them behave similarly.
Thanks in advance
Old Nov 10, 2018 | 10:36 PM
roy7777's Avatar
roy7777
You mean the silver square part, right? That looks like HID ballast. Can you remove it? Take a look at this IS ballast remove video, maybe they are alike.
Old Nov 13, 2018 | 06:45 AM
captainva's Avatar
captainva
If you're replacing your headlight you should replace it with the same type. If the original is HID the replacement should be HID. You can change the headlight type but it will almost certainly require wiring changes to the car.
Mikera
Jun 24, 2023 11:54 PM
GeeRodreez
CL of Southern California
Nov 19, 2013 06:28 PM
lixster
Apr 5, 2010 06:59 PM
melski415
Apr 2, 2010 09:24 PM
LEXISM
Jul 1, 2005 08:34 AM
