Sponsored by: CARiD
HID install problem
Old Jul 25, 2003 | 06:12 PM
rice_rocke's Avatar
rice_rocke
Default HID install problem
I have a problem with my install of HID's. I have a phillips complete kit, for the 9006 retrofit and a D2R bulb. Standard Phillips basically.
Anyways I have a problem with my passenger side light/ballast not lighting up! The weird problem starts here.... both the setups bulbs, ballasts etc work perfectly fine on the driver's side, yet on the passenger side it won't light up at all!
Now what's wrong with that? I plug in the stock 9006 bulbs and it lights up, so that's fine, but why doesn't it fire up the ballast?
Now I thought.. heck I'll just leave it like that, go for a 30 min drive or so. After about 10-15 mins my lights go out, the brake light, battery light, and alternator light goes on. Crap I thought I melted something. Went back home, found out the headlight 40A fuse blew, got a new one and everything is back to the same problem.. the passenger side light doesn't go on.
Can someone tell me what could be the problem here? Any weird possibility that the passenger side doesn't produce enough current to light the ballast for some odd reason?
I would assume there is no point in trying another HID kit (which I don't have handy).. and I don't really want to return this one since when I swap sides both sets work.
Thanks!
Old Jul 25, 2003 | 06:57 PM
rominl's Avatar
rominl
exclusive matchup
oh man....... you should have asked it earlier here.... what happened is on your pessenger side, the stock power connector is connected to the ballast for the pessenger side right? look at the wire, it's flipped. the red is connected to black now. flip the wires and you are good to go
Old Jul 25, 2003 | 07:03 PM
PHML's Avatar
PHML
Master Thread Closer!!
https://www.clublexus.com/forums/sho...t=HID+Retrofit
Old Jul 25, 2003 | 07:40 PM
rice_rocke's Avatar
rice_rocke
Oooh, okay let me try that I'll post if it works. Anything bad could happen if it's not that and I switch the wires? I just need to switch the wires at the stock plug, I am assuming I can also switch the wire at the ballast plug that goes into the stock plug (I think it has a clip so I can switch it)
Old Jul 26, 2003 | 03:43 PM
rice_rocke's Avatar
rice_rocke
Alright! It worked! Boy, and you think maybe they should have put that in the instructions somewhere.. or at least made a left and right.
Thanks for the help, looks awesome!
Old Jul 26, 2003 | 10:30 PM
rominl's Avatar
rominl
exclusive matchup
haha guess we read the thread too late anyway, yeah, it's that easy. welcome to the club!
Old Jul 26, 2003 | 10:48 PM
rice_rocke's Avatar
rice_rocke
Thanks a lot! Oh, and a note... the wires actually had the "colors" correct, but I just took a leap of faith and thought the worst would be a blown fuse. Now my wires don't actually "match" but it's up and running! Time to get some HID's for the RX300.. hehe, maybe the 330's new headlights can be a direct fit... hmm time to go searching
Old Jul 27, 2003 | 03:02 AM
PHML's Avatar
PHML
Yah....welcome to the HID club....glad to hear u got them up and running.
Pete
jbrooksga
Mar 29, 2011 11:53 AM
06MiCa
May 26, 2009 04:11 PM
Lilflip#2
Mar 10, 2009 08:44 PM
carlos
Lighting
Mar 11, 2006 07:24 AM
BigD026
Lighting
Dec 23, 2003 07:55 PM
