Sponsored by: CARiD
What causes this?
Old Jun 20, 2003 | 02:31 PM
4double0's Avatar
4double0
Question What causes this?
Hey guys, what causes one hid headlamp to be brighter than the other? From a head on view it seems fine, but when I bend down and look into the lamps the driver side lamp is way brighter than the passenger side lamp.
Old Jun 20, 2003 | 02:45 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
i could be wrong, but i believe they are a direct focus beam and biasing yourself a little each way will take you "out of the path" and make it appear as you say.
Old Jun 20, 2003 | 06:44 PM
rominl's Avatar
rominl
exclusive matchup
try this. from a distance, stare at your grill, gradually bend down, at some point, the hid will "suddenly" glare at you. if they glare at you at different time, that means your hid lights aren't aimed correctly
Old Jun 20, 2003 | 11:53 PM
see_fu's Avatar
see_fu
One projector seems brighter because of the flare. If you're standing directly in front of your vehicle and looking right at the middle of your car, the driver side should ALWAYS seem brighter and cause glare first as u crouch lower and lower.
Old Jun 21, 2003 | 10:26 AM
Jmai22's Avatar
Jmai22
why is that? don't both headlights have the flare?
Old Jun 21, 2003 | 01:35 PM
see_fu's Avatar
see_fu
yea both have the flare, but if you're standing right in front of your vehicle, the flare on the passenger side projector hasn't begun yet.
jadeboy
Aug 19, 2010 12:17 PM
SpamLite
Mar 15, 2009 06:09 PM
nioks
Feb 26, 2008 12:55 PM
MIKE313
Lighting
Aug 25, 2004 09:50 PM
Poelee
Lighting
Mar 22, 2003 08:21 PM
