Sponsored by: CARiD
99 ES300 HID ground shadow
Old Dec 11, 2014 | 04:59 AM
matt303277's Avatar
matt303277
Default 99 ES300 HID ground shadow
I installed 8k xtreme hids in my low beams and fogs. The fogs look great, but I noticed while on the road, the lows were creating a weird ovally shadow on the right side on the road. As I pulled into my driveway, my lights shined onto my garage door and I noticed that my right headlight was way lower than my left. I raised the right up to alignment with the left, hoping it would eliminate the problem. This got rid of the shadow but now its making an even worse looking shadow. It looks like a cluster of light fractures. Wish I could explain this better but I have no idea how to post pics.
Old Dec 11, 2014 | 05:14 AM
matt303277's Avatar
matt303277
Uneven lights
Ovally shadow on the ground
After I leveled the lights
And bow it looks like this :/ please help lol. Also there is so much play in the bulbs like the clips are not made to hold them in
Old Dec 11, 2014 | 08:57 AM
matt303277's Avatar
matt303277
___UPDATE___
here is my reflector lens. in good shape too. now i know there will be a slight distortion since i am not using an HID headlamp, but it shouldnt be anywhere near this bad.<br/>
passenger side housing ( notice the base of the bulb is just resting in there. the clip keeps it from falling out but there is still a huge amount of play, as i can basically twist the bulb 360 degrees and tilt it side to side, up and down.
drivers side, closer view
Old Dec 11, 2014 | 06:40 PM
01LEXPL's Avatar
01LEXPL
Two things, those HID's look to be junk! Two colors that are way off... [the temps]
I had HID's in my old ES300 and the light was not that distorted [before I bought the HID headlamps].
Second, the problem with the bulbs is that you installed them wrong!
Read this; http://goldwing.eurekaboy.com/hid.htm
Basically, the H7 bulb has a connector that a normal bulb sits in, which is held in by that metal clip. You say its moving around, well, you didn't substitute the new bulb with the same type of adapter.
Just google H7 hid adapter, or spacer. They make the aftermarket, or... you can be crafty and simply get creative with a hot blade and splice the factory one up.
Good luck.
Old Dec 12, 2014 | 07:29 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
matt303277: Did the H7 halogen bulbs sit in a adaptor? If so can you provide a picture of them? The pattern may be related to the fact that the bulbs are not sitting in the housing correctly.
Danny
Old Dec 12, 2014 | 11:38 AM
matt303277's Avatar
matt303277
This was the adaptor thing attached to my OEM halogen bulb.
And it comes out like this.
So I would plug that adaptor into the HID kit prongs that go into the factory harness and then the other end of the adaptor into the factory harness female end I suppose? The only thing I don't get is where all that extra wire from the HID kit is going to go? would have to go inside the housing or something? And wouldn't that create an even bigger shadow with wires inside the lenses?
Old Dec 12, 2014 | 01:38 PM
NYC ES3's Avatar
NYC ES3
hollow out the adaper in between the prongs in the back.... you his light wires will pertrude out the back thru the hollowing out you made...but the adapter will hold the bulb in. with the metal clips. basically just grind it away till there is enough room to pass the his cable through.
Old Dec 12, 2014 | 01:41 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
It looks like you will need the following H7 bulb adaptor:
http://www.kbcarstuff.com/H7-HID-Kit...2-p/h7-adp.htm
Old Dec 13, 2014 | 11:09 AM
matt303277's Avatar
matt303277
Which way should the ground wire on the HID bulb be facing for the best appearance and no shadows?
Old Dec 13, 2014 | 02:21 PM
matt303277's Avatar
matt303277
(On my reflector lenses that is)
Old Dec 15, 2014 | 07:33 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Hi,
The bulbs will only install one way due to the locking tab on the base of the H7 bulb.
Steve
Old Dec 16, 2014 | 11:19 AM
NorthStyle's Avatar
NorthStyle
Poor, poor oncoming traffic...
Old Dec 24, 2014 | 07:02 AM
matt303277's Avatar
matt303277
Default __update__
Rigging the old adaptors didn't go so well, so I purchased them and lights fit great now. I am still getting a slight shadow but I know I would because I am using reflector lenses. Any tips on how to correctly align headlights? Right now I have the driver side slightly lower to reduce glare and having gotten any people flashing lights at me. But I played around with the horizontal adjustments too and not sure the exact position they should be?
Old Jan 8, 2015 | 08:53 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Our bulbs are laser aligned to keep the focal point in the same place as your halogen bulbs. You shouldn't need to make any adjustments. Most headlights will have screws to adjust the horizontal and vertical angle of the lights if you want to make adjustments though.
John
gswain
Jun 23, 2015 01:55 PM
jamrocklex
Aug 15, 2014 09:04 AM
olivelexus
Jul 16, 2009 11:58 PM
KillaSC209
Jul 14, 2009 08:41 AM
D-MAN63
Lighting
25
Apr 13, 2005 11:11 AM
