Installing Interior and Exterior Neon/LEDs
Old 10-15-13, 04:10 AM
BlackDog59
BlackDog59's Avatar
Default Installing Interior and Exterior Neon/LEDs
Hey guys first time posting here. I'm in Okinawa, Japan and just acquired a 91 Celsior in May of this year and wanted to add a few personal touches to the car. Unfortunately I'm new to the Mods scene and am having a terrible time figuring out exactly how to mount an underbody light kit. Unlike with most cars where there are plenty of places to drill and mount things I cant seem to find a decent location to do this. Another Problem would be wiring. Absolutely no experience with wiring things to the battery or from the battery to a switch to control them from the inside. Another problem is finding a place to put said switch if i can get my hands on one. Any help with this matter would be greatly appreciated. Thanks in advance
-Chris
Old 10-23-13, 08:21 AM
Boomer9094
Boomer9094's Avatar
Default under body light kits
I have LED light bars under my 1995 LS400. not the easiest install I have done. and I have installed these and removed them many times. first make sure you have them lined up the right way. wires to the front. you also want to make sure you are far away for jack up points. lay it all out first. I was 6 inches short from the rear light bar to the control module. so I had to relocate the control module to under my steering wheel. I hooked it all up to a switch so I can have a master on/off I don't use it too much it can only be seen at night. you have to add a smoke machine to light up in daylight. but that's another mod for another day. depending on you car the most difficult part is running the wires into the car and through the firewall. not a lot of room to get a drill in there on a Lexus
PhatDad
03-04-15 07:59 PM
Dtcsurfer
IS - 1st Gen (2001-2005)
04-11-13 10:24 AM
CCJ22
08-08-12 05:32 AM
Hal56
RX - 3rd Gen (2010-2015)
12-15-09 08:35 AM
PeteinPA
04-07-09 05:51 PM
Quick Reply: Installing Interior and Exterior Neon/LEDs
