Sponsored by: CARiD
Moisture In Headlight!!!
Old Jun 5, 2002 | 06:00 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Angry Moisture In Headlight!!!
I can't believe I have moisture in one of my headlights My RX sat outside this evening (as it always does) and it is warm (80's) and rainy.
My first suspicion is this has something to do with my HID kit. I.E: there isn't a good seal where the headlight goes into the housing. But, I don't think that's the case because I have moisture inside my foglight area too, which has not been touched. What should I do? Put the halogens back in and make a trip to the dealer?
Old Jun 5, 2002 | 06:01 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Old Jun 5, 2002 | 07:48 PM
Daddy-O's Avatar
Daddy-O
Hmm...Only on the drivers side?
Did you drive it in the rain?
If so, how fast?
Old Jun 5, 2002 | 08:06 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Yeah, it's only on the driver's side.
I drove over to a friends house around 6pm - it hadn't been raining at all today. When I got back around 9pm it had been raining. So, it fogged up while sitting in the rain
I dread taking it to the dealer...I'm guess I'll remove my HID's so they don't blame that and try to void the warranty claim. I also think I'll take my a prental unit with me so we can get a loaner...I can't get a loaner yet since you have to be 21 to get one.
Also, if the replace the housing I would like for both to be replaced. It would look odd having a new and used one...to my trained eye at least
Old Jun 5, 2002 | 08:36 PM
Sooner's Avatar
Sooner
that is somewhat common on the rx's dont worry bout rmoving anything it will be fine.any questions or problems pm me or ask fairuza11
Old Jun 5, 2002 | 10:08 PM
Shonuff's Avatar
Shonuff
nick, you need to replace that yellowish colored parking light.....hahaha.
Old Jun 5, 2002 | 10:23 PM
LexRX's Avatar
LexRX
RX 300 & 350Z Guru
Yeah, it looks really bad in the pic b/c I used the flash - it's not really that dim. I like it though because it contrasts with the xenon making them look more clear/blue. My digicam also shows more green where there should be more blue.
Old Jun 10, 2002 | 09:36 AM
Handogen's Avatar
Handogen
I have to say it's nice to know I wasn't the only person who had this problem...
I had a problem with humidity in the right front headlight when I lived in Oregon. I moved out to the Denver area in March and haven't had the problem since... it must be the moisture in the air.
When I took it to the Lexus Dealer in Oregon, he said they had never seen anything like it and couldn't explain what the problem was. Sounds like a brush off to me... especially from what I've read in these forums. Several of you have had this common problem as well.
I'm thinking of buying new ones in the future... probably one of the newer tinted sets you see on the 2001/2002 models.... I'm just waiting to find the right deal. The newer ones look much better IMHO.
Hando
Old Jun 10, 2002 | 02:23 PM
malhokc's Avatar
malhokc
I had a similar problem with the moisture in the driver side headlight. I think it's due to the aftermarket bulbs not fitting well. But then the other should get the moisture also. Luckily, the dealer replaced at no cost to me.
Old Jun 10, 2002 | 09:39 PM
MrSypher's Avatar
MrSypher
Nick, I haven't read anyother posts execpt yours.... It is late and I figured I'll throw you a bone.... Tkae the HID's out and bring it to Lexus.... The Head lights/ Highs and Fogs are all one unit.... Hopefully you are still under warranty???? If so they'll replace it for you.... And if you wait alittle bit and have them put in the HID's for you.... So if anything happens after that it's there fault..... Hope this helps Nick........
Old Jun 10, 2002 | 10:42 PM
Hermosa's Avatar
Hermosa
And then remember to install the HID kit on a hot dry day and make sure the chamber is sealed or you will repeat this incident.
Old Jun 11, 2002 | 10:55 AM
Jeff92se's Avatar
Jeff92se
When I was shopping for our RX for the wifey, I had a chance to see 4-5 used 99's on the Lexus lot. Most if not all had either moisture in the lights or signs of previous moisture(ie.. dried up stains inside the housings that dulled the lense). I thought was odd(and made the housings look bad). I would pretty much demand a warranty replacement. Our 2000 RX has not had the problem(nor has it had signs of a previous problem) but it sits in our garage at night.
Old Jun 18, 2002 | 04:09 AM
nerdspeed's Avatar
nerdspeed
Default omg
I JUST GOT MOISTURE TOO!!
Old Jun 18, 2002 | 07:51 AM
wwest's Avatar
wwest
Default heat "cycling"
in humid climates/weather will do that if the headlamp is not completely and fully sealed. You can fix it temporarily by heating the assembly by running all lamps (incandesent) for awhile and then inserting the business end of a vacuum cleaner hose into the bulb socket area with a reasonably good seal. Low atmospheric pressure, slight vacuum, will cause the moisture to convert to a vapor (gas) and the vacuum will whisk it away.
Old Jul 7, 2003 | 01:30 PM
seang2's Avatar
seang2
I've been reading up on this moisture problem. I checked out a car today that I am considering purchasing. '93 SC400. I noticed that the driver's side front headlight had moisture, as well as the driver's side rear light (which was cracked).
I kept asking the guy about it, and all he could said was that it would pass inspection He totally missed my point of what could be done about it.
Will this cause any major problems? Should the guy selling the car (used dealer) be expected to do anything about it?
