Sponsored by: CARiD
74/T5 LED mini wedge bulbs
Old Feb 5, 2010 | 08:11 PM
potatoBBQ's Avatar
potatoBBQ
Default 74/T5 LED mini wedge bulbs
The 74/T5 LED mini wedge bulbs I got from warden_jp2002 fit very loose in the socket. They will literally just fall out of the socket unless you secure them some other way. I figure most of these probably come from the same factories in China so I'm guessing they are all going to fit sorta loose, but has anyone bought any from other vendors like autolumination, v-leds, etc. that fit right?
Old Feb 5, 2010 | 08:21 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
warden jp ones are crap...also the ones from superbrightleds dont last long.
Old Feb 5, 2010 | 11:01 PM
daryltrinh's Avatar
daryltrinh
CL Folding 500,000
I ran into the same problem.
I literally had to thicken the bulb with paper to make it fit.
Old Feb 6, 2010 | 01:47 PM
potatoBBQ's Avatar
potatoBBQ
Yeah, I ended up doing the same thing and stuck a piece of paper between the contacts and the base, but it's still not in there very securely.
Which ones aren't crap (if any)?
Old Feb 6, 2010 | 04:18 PM
YeA 2jZ's Avatar
YeA 2jZ
I have them and they fit perfect ????
Old Feb 6, 2010 | 04:40 PM
01LEXPL's Avatar
01LEXPL
Yeah, right away bud. Bulbs are bulbs, but being LED's they need to compensate by being a little bigger in size.
OP, you have to modify the slot to make it fit.
I am not going to reiterate what i had to do to these twice in my ES300 to make it fit. And i bought 90% of the bulbs from Warden_jp2002, and i continue to swear by him...
Check it for pics: https://www.clublexus.com/forums/4699347-post4.html
And a shameless plug here, but here is the whole thread!
https://www.clublexus.com/forums/es3...h-of-leds.html
Best,
Mike
Old Feb 6, 2010 | 06:45 PM
potatoBBQ's Avatar
potatoBBQ
Best,
Mike
Thanks a lot, great write up for the ES! I guess I should have also searched the car specific forums instead of just the Lighting forum. It's exactly that glove box light that I was having problems with on my SC and I wasn't sure whether or not I could remove the entire assembly so your pics were very helpful.
Old Feb 6, 2010 | 08:08 PM
01LEXPL's Avatar
01LEXPL
No worries!
At least someone else will benefit from my write-up, i can tell you now, on the ES it was a *****! Just an awkward position to get my hand in there to pull it out; just be patient with it!
Old Feb 6, 2010 | 08:22 PM
FinLIFE's Avatar
FinLIFE
I had warden and not only did I get blue instead of white, but they were loose as well. I switched over to v-leds with no problems so far
Old Feb 7, 2010 | 04:42 AM
potatoBBQ's Avatar
potatoBBQ
Do you happen to remember which v-led 74/T5 mini wedge leds you switched to? They have a few different 74 led designs/configurations so I want to make sure I get some that will fit correctly this time.
Old Sep 25, 2018 | 05:12 AM
11Es350Lex's Avatar
11Es350Lex
im new and this is my first post I replace the 74 wedge ash tray and gear shift bulbs to led. At first the new lights didn’t want to stay in but just don’t be scared put a cloth over the new bulb and push it into the socket until it clicks in, don’t be afraid to use pressure.
johnnylt
Jul 30, 2018 03:06 AM
NXOwner
NX - 1st Gen (2015-2021)
102
Jul 13, 2017 06:25 AM
ranez0r
Jun 13, 2009 05:16 PM
cyberflip9
GX - 1st Gen (2003-2009)
Apr 15, 2004 09:07 PM
