Sponsored by: CARiD
What does retrofitting include?
Old Aug 21, 2006 | 04:40 PM
Sweetser's Avatar
Sweetser
Default What does retrofitting include?
When you "retrofit" your lights to HID's, is this basically just taking the Projector Housing from a vehicle that has HID (like Audi, BMW, etc) and putting it in our stock location? Then adding the HID kit with the harness, ballast and Phillips bulb?
Old Aug 23, 2006 | 05:00 AM
SOHKis's Avatar
SOHKis
CL Folding 200,000
pretty much...
You remove the projector unit from the original factory headlight, then you find a way to mount it into your reflector housing so you can retain the factory leveling adjustments. The most important part when you mount the projectors is making sure your cutoffs are level in terms of rotation, since you will be able to adjust them up/down the the factory adjusters.
If you already had a reflector HID setup you can usually leave the ballasts where they are, but if you had a halogen setup you'll have to mount the ballasts also. Check out hidplanet.com/forums for more info, their site has been on the fritz recently though.
Old Aug 23, 2006 | 08:45 AM
darksparkz's Avatar
darksparkz
But if we have halogen setup, we'd have to cut and make room for the projector to fit in and be tight?
Old Aug 23, 2006 | 08:49 AM
SOHKis's Avatar
SOHKis
CL Folding 200,000
yeah, usually you will cut a hole in the original reflector where your halogen bulb used to sit so that the projector can sit inside the old reflector. This locates the new HID bulb in about the same place as your original bulb. You'll have to make sure it doesn't hit the back of the housing, as well as the front (clearance issues). You will want to mount the projector as far forward as possible to get the best output, but you also don't want to hit the front lense with the projectors lense.
There's ALOT of good info here if the site is up:
http://www.hidplanet.com/forums/view...b415631b601f39
waxman
Feb 6, 2017 04:08 PM
tarneckir
RX - 1st Gen (1999-2003)
Dec 24, 2015 01:52 PM
Thinktwice
Apr 30, 2011 06:28 AM
LarsLexus
Apr 18, 2011 06:46 PM
Stage3
Lighting
Aug 30, 2008 08:19 PM
