Sponsored by: CARiD
LS400 Light Types?
Old May 26, 2005 | 12:03 AM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
Default LS400 Light Types?
1995 Lexus LS400
what sizes fit into the headlights/interior lights? the owners manual leaves a lot out and gives no bulb no. im looking to do all the lights in LED except for the head/fogs which i want silvania (but dont know which size since they say its 900x and manual says HB4/B3/4). what is the best replacement for the Dome light(in the front?)
Thanks in advance
Old May 26, 2005 | 05:30 AM
lexusk8's Avatar
lexusk8
You can find info on bulb types on any vehicle at Sylvania
Old May 26, 2005 | 03:51 PM
PureDrifter
BahHumBug
CL Folding 100,000
i went there and it seems like they are off a bit.
ex.-Manual lists foglights as HB3 and sylvania lists as 9006
Old May 26, 2005 | 04:42 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Technically they're not off because HB3 is the same as 9005...and 9005 is essentially the same as 9006, but without the shield/cap.
9005 (HB3) on left and 9006 (HB4) on right:
Old May 26, 2005 | 06:25 PM
PureDrifter
BahHumBug
CL Folding 100,000
so if HB3=9005 and HB4=9006, then what is H4?
Additionally, i want to do something similar to engin_ear and his GS, but im unsure if its the same bulb no.s for a LS
https://www.clublexus.com/forums/sho...d.php?t=161745
im looking for a pair of superwhite bulbs for the maplights, and a mixture of Blue and Green/Purple LED lighting for the footwells, courtesy lights, and dome light. any help would be appreciated and would somebody please tell me if the sylvania replacement guide is 100% acaccurate?
Thanks
-PD
Old May 26, 2005 | 08:35 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
Thanks
-ANnant
H4 = 9003.
I used polarg M-26 bulbs for the maplights in my '91:
http://216.82.69.117/detail.asp?PRODUCT_ID=M-26
You can get the LEDs at http://autolumination.com/194.htm or http://www.superbrightleds.com/1157.htm. You'll be needing #74's for the footwells and #194/168 for the courtesy lights (I suggest the Oval Wide Angle lens bulbs, but the 4 to 6 LED would work nicely as well). I wouldn't suggest an LED for the dome light because it does not put out enough lighting compared to a halogen superwhite bulb.
It seems the sylvania replacement guide is accurate so far, but I wouldn't say it's 100%...it's more like 98%.
Old May 26, 2005 | 09:01 PM
xirforever's Avatar
xirforever
I put the 4 LED dome light in on my car, love the color. It doesn't light up as good as an incandesent bulb would but it deffidentally is bright enough for me, I can see everything when i get in and im a happy camper
Old May 31, 2005 | 09:20 PM
PureDrifter
BahHumBug
CL Folding 100,000
thanks for the help guys, im about ready to finally order these things. only thing is, there are so many on superbrightleds.com that im totally lost on what to order. im hoping to replace the following.
footlights
door courtesy lights
dome light
glovebox light
both interior courtesy lights in the REAR but not the MAP lights in the rear.
and i also need to replace the parking lights if anyone knows what bulb size those are please tell me.
thanks in advance!
Iwearshaqs
Jun 24, 2018 04:40 AM
stickyrick
Nov 13, 2008 12:10 PM
lenunn1923
Feb 26, 2008 01:43 PM
black_LS
Sep 1, 2007 12:29 AM
brian3268
Lighting
Mar 25, 2003 09:04 AM
