Used Smartkey Smart Fob Programing
Hello Iv been searching the internet and have not found the information needed or it was too buried in the forums.
If one buys a used fob with matching FCC ID original and it was programmed to another car it will not be able to be used in conjunction with the standard bootleg techstream software protocol.
I think the ECU must be relearned or something and it will require a seed code which requires a genuine subscription to TIS.
My question
Is there a way to clear the smart fob?
Reprogram the EEprom?
My used fob from ebay
FCC ID HYQ14AAB
IC: 1551A-14AAB
It uses a Texas Instruments Chip
30 pins 15 on each side
3712c3x
604
TEDXV
and unmarked
BU9870FV
608 T73
I was hopeing it was simple as reading chip and changing some values?
if anyone with extra knowledge can shed light to this?
If anything i may take my original and copy all values and replace on the used chip?
Which might seem illegal because you might not be able to change some values and Mac or IMEI addresess legal and this is for educational and research purposes only and i do not condone any illegal activity.
Thank You
My question
FCC ID HYQ14AAB
IC: 1551A-14AAB
3712c3x
604
TEDXV
and unmarked
BU9870FV
608 T73
Thank You
jehmin
04-20-17 05:12 AM
