Volume on navigation
Old May 9, 2003 | 06:35 PM
Houston GS's Avatar
Houston GS
Registered User
Default Volume on navigation
Is it possible to increse the volume above the "7" setting for the voice command associatied with the nav system? With the stereo at moderate levels you can't hear the voice prompts? I called the 1 800 number for Lexus customer support and they did not think so. It is just so soft, I would think they could kick all to a higher level?
Does anyone else have this problem?
Old May 9, 2003 | 06:59 PM
What? I'm sorry, I can't hear you.
Maybe you've played your stereo so loud you're deaf!
Old May 10, 2003 | 08:18 AM
Hohlraum's Avatar
Hohlraum
AFAIK the nav (atleast on my GS430) only speaks out of the left door speaker. I wish they could make it so it came out of all the front speakers. I can't hear it for **** unless i turn off the cd/radio.
Old May 11, 2003 | 06:31 PM
LS4fun's Avatar
LS4fun
Default Re: Volume on navigation
I agree..i think its a weakness....
Old May 21, 2003 | 10:52 PM
robinzon's Avatar
robinzon
Same on the GX470. It speaks out of the Left speaker plus it does not mute the radio as I think it should. Considering that supposedly it has the ADAPTIVE volume control why the hell would it not mute the radio.... its rather odd...
Old May 22, 2003 | 01:17 AM
bravo261's Avatar
bravo261
yeah, it really should reduce music volume as it talks to you. left speaker, i undestand that one though
Old May 22, 2003 | 10:59 AM
Hohlraum's Avatar
Hohlraum
only problem with the left door speaker is that I'm a big guy, my leg drastically muffles the sound coming out of that speaker the way it is.
Old May 22, 2003 | 01:34 PM
LS007's Avatar
LS007
The navigation voice comes out of the front left speaker by the navigation ECU intercepting the speaker wires from the amplifier. The navigation voice could be played out of it's own speaker by taking the ECU audio output wires directly to a speaker or even rewired to a LLC and then into the preamp side of the stereo. The navigation voice volume level would then be adjustable with your stereo volume. The later would be a big job, but could be done.
Old May 26, 2003 | 08:34 AM
Lexopolis's Avatar
Lexopolis
No, 7 in the max, there is no sub-setting to change. f you are using NAV, usually you are trying to pay attention to the directions, keep the radio down a bit.
RS27
Jan 10, 2014 12:14 PM
Creid
20
Feb 4, 2013 06:24 AM
BobsGX
GX - 1st Gen (2003-2009)
Jan 9, 2006 05:26 PM
Kash
Oct 13, 2004 07:29 PM
angelslex
Feb 13, 2003 10:59 AM
