Enclosure Update Almost DonE!!!!
Old Apr 11, 2003 | 07:15 PM
BigghookUp's Avatar
BigghookUp
Talking Enclosure Update Almost DonE!!!!
Heres some new pics i added the flames and mirror tape what do you all think for a first sub enclosure?
Heres first pic without flames:
Old Apr 11, 2003 | 07:16 PM
BigghookUp's Avatar
BigghookUp
Default Flames!!!!
Here is the box with the flames!!!
Old Apr 12, 2003 | 06:55 AM
BigghookUp's Avatar
BigghookUp
more pics of progress will come soon.
Currently deciding between either using carpet on the outside of using vinyl.
Can you guys discuss the pros and cons of each, (prices, durability, etc looks)
Future plans:
Get the plex glass on in the front,
Getting everything sealed
Covering the outside
Buying the subs and amp (jl wo's 12in, not sure which amp)
Cutting the holes for the subs
Making the platform behind the plexiglass in the middle for the amp.
Buying 6in red neon lights
Then installing in car, once i get it lol, then i will start building my next box which wiill be sale for new england residents.
Peace
Old Apr 12, 2003 | 11:05 AM
BigghookUp's Avatar
BigghookUp
I've got a question about the amp setup, would it be smarter for me to leave an opening in the back so i can controll the power, or get an equalizer so i can place it in a confortable location so i wont have to keep going behind the box and opening up the back and then controlling it, all opinions are welcome, thanks
Old Apr 12, 2003 | 07:17 PM
TimDimman's Avatar
TimDimman
Future plans:
Peace
Where did you get the mirror tape? The flames look very nice!
Carpet vs Vinyl.
They are about the same price.
Carpet is FAR more durable than vinyl (A nick in the vinyl and your doomed!!! The white underside will show through).
I personally think vinyl looks better.
Vinyl stretches (depending on the backing you get) but it is very unforgiving. It will show all your defects underneath it. Carpet will cover them. With vinyl, you can add graphics underneath (any type of raised surface) and they will show through. The application is the same (I use 3M Super 77) however, the vinyl will show the "merged" seams very well, the carpet can be brushed so that they don't show.
If this is your first attempt, I'd buy a ton of vinyl and practice, practice, practice. Make sure you have a heat gun (helps to stretch it). If you don't want to put up with the hassle, carpet does look nice, and its very durable and very forgiving.
Tim
Old Apr 12, 2003 | 07:19 PM
TimDimman's Avatar
TimDimman
An equalizer will round out the system very nicely. It will also help to eliminate any cabin curve "bumps" that you don't like.
I'd recommend an EQ.
You should also leave yourself an opening to adjust the amp without having to unmount it (if possible) or design a fascia board that you can easily remove.
Tim
Old Apr 12, 2003 | 10:48 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
your supposed to run a thin layer of foam padding underneath the vinyl. If done properly, it will look excellent. if you choose to thicken the foam up any, the sub will appear to countersink into the vinyl.
Old Apr 13, 2003 | 02:02 AM
TimDimman's Avatar
TimDimman
Sorry, don't mean to step on your toes...
This is true...I'm not sure of the level of experience of the thread originator, but foam backing isn't a cure all. Even with foam, board edges which don't properly meet flush, or screws which aren't counter sunk properly will show (more so than carpet).
Tim
Old Apr 13, 2003 | 03:41 AM
BigghookUp's Avatar
BigghookUp
To answer you question about where I bought the mirror tape, well all products that were used in this project were bought at home depot,
Also thanks for your inputs, i really appreciate it.
Old Apr 14, 2003 | 01:19 PM
BigghookUp's Avatar
BigghookUp
Heres an update:
Old Apr 14, 2003 | 01:20 PM
BigghookUp's Avatar
BigghookUp
back:
Old Apr 15, 2003 | 04:12 PM
BigghookUp's Avatar
BigghookUp
More pics of case with holes to come soon, also just bought the felt and had a question about how you get it on.
I asked the local B+D autoshop and they said use the spray adhesive.
Will this work best? i thought of using a nail gun and then took it back because I'm dealing with fiberboard?
Will anything else work as well but a little cheaper than 7$ a can?
Old Apr 15, 2003 | 07:02 PM
TimDimman's Avatar
TimDimman
Depending on the backing...possibly contact cement.
If you are using felt, be very careful, as you can easily soak the felt with the spray adhesive. This will turn out horrible.
3M's Super 77 is what I usually use. I find it works well. Spray both the surface you are covering, and the covering itself...wait a little while, then apply the covering material to the surface. Remember to stretch as necessary.
Use a brush to hide the seams (brush the material to cover the seams), or hide them if possilbe .
Tim
Old Apr 15, 2003 | 07:03 PM
TimDimman's Avatar
TimDimman
Oh, and wear a nuisance filter and goggles!!! The worse feeling is a "sticky nostril" feeling after inhaling the adhesive fumes. I just bought a box of filters from Home Despot. They are cheap, and well worth it!!!
Tim
Old Apr 15, 2003 | 10:33 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
sticky nostril.. omg.. i have been there. i really dont like the sprays myself, but they are good for certain applications. i always tend to see the adhesive weaken in heat and peel back if sprayed, but of course this isnt always the case. when i apply anything to wood, i always cement it and use a spreader for uniformity. the novice will enjoy the spray, the more advanced user will be able to use the cement more effectively. there is a time and situation for both, so neither can be ruled out. i just hate having to re-adhesive something after the temp rises above 85. even with the spray, pull apart, respray technique i always have bad luck from the compressed adhesive. i did however get a gallon of adhesive from 3M once that i poured into a airgun and it shot a purple/pink color.... that stuff holds like nails!!
