Audio noise
Old Dec 29, 2002 | 08:04 PM
dipstick's Avatar
dipstick
Default Audio noise
I seem to have a problem. On cold mornings, for the first 5-10 minutes, my stereo system makes a kind of heavy static "tuk" sound when I brake, or go over bumps, etc. It seems like something is touching something when the car moves up and down on the suspension. This started after my L-Tuned suspension installation. Anybody ever have this problem? Any ideas from you sound system guys? After a few minutes it goes away. It is the Mark Levinson system.
Old Dec 29, 2002 | 08:57 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Sounds like a ground issue, but it's unusual it would go away after a few minutes.
Dipstick - I'm also moving your post to the electronics section so you'll get responses both on the redirect from the GS forum and the experts here.
Old Dec 30, 2002 | 10:40 PM
DaveGS4's Avatar
DaveGS4
Gene / Percy / Retro - any ideas?
Old Dec 30, 2002 | 10:50 PM
dipstick's Avatar
dipstick
Default More on problem
Today it is happening all day, even after warmed up. I'm going to check connections to my subwoofer tomorrow-- I have had big boxes stacked in there lately (springs, shocks, sway bars) maybe I bumped something.
Old Dec 31, 2002 | 05:10 PM
retrodrive's Avatar
retrodrive
Search Function Inc.
Check your grounds. Usually if your ground wires are not securely bolted down, or if you did not remove the paint before installing the ground, you would pick up an alternator noise. When you are pressing accelerator,, your alternator spins faster giving your system more noise and vise versa when you brake. In the morning you might get some water residue on your connections. That too may cause a bad ground. To take care of that problem, just put a thick layer of durable paint on your ground connection.
Old Dec 31, 2002 | 06:10 PM
dipstick's Avatar
dipstick
Default and more....
I discovered today that it only happens on AM, not FM. Does that help? It is sounds like someone is tapping on a connection with something metallic, when the car bounces up or down. ??????
matson
Feb 2, 2019 07:54 AM
Shelby2011
GX - 1st Gen (2003-2009)
Feb 18, 2013 03:35 PM
barry_s
Dec 29, 2006 10:07 AM
fbapacible
Suspension and Brakes
Oct 2, 2004 07:41 PM
Captain Bone
Feb 25, 2004 08:16 AM
